Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-17-2023, 12:56 PM | #1 |
Drives: Toyota GT86
brass vs steel
I placed an order for a M18x1.5 to 1/8NPT adapter to be used for installing a oil pressure sensor in the factory oil galley near the TB.
When looking for TQed specs which I still have not found yet I found a post saying to never use brass in a high vibration area as it will come loose and to always use steel. "Never use brass or aluminum in a high vibration area. (AKA screwed into a block) Steel is always good." A quick google search for a steel adapter brought me to killer B. Who also can't tell me the tq specs when asked over email... Does it make sense to order another adapter ? has anyone had experience with either of these adapters or know the tq specs lol Brass adapter I ordered https://www.iagperformance.com/prosp...-ej25-engines/ Steel one https://www.killerbmotorsport.net/m1...pter.html.html Thank you
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
08-17-2023, 01:09 PM | #2 |
chicken tonight
Doesn't matter in that application. The vibration mostly comes into play when the part can flex like a tuning fork. Resonance will kill steel just the same as any other metal but it can tolerate limited cyclic strain indefinitely. Think springs. Can't make a spring out of aluminum or brass.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
08-17-2023, 01:15 PM | #3 | |
Drives: Toyota GT86
08-17-2023, 01:18 PM | #4 |
chicken tonight
No sweat. One would go insane chasing after all the misinformation on this, or any other forum. It's a great discussion.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (08-17-2023), soundman98 (08-17-2023) |
08-17-2023, 01:58 PM | #5 |
Drives: Crapcan
I've been using brass fittings for over 6 years, no issues yet. One of them I milled a bit even on the 1/8bpst side because my transducer probe wouldn't fit through the original hole. If I was using a straight fitting with a long transducer or temp sensor on the timing cover, i'd probably spring for steel just for the safety. As Ultra said, application is key.
You can also just search 1/8pst thread torque and get a generic spec. Most of the time this is good enough. https://www.engineersedge.com/hardwa...tion_13424.htm
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
08-17-2023, 02:16 PM | #6 | |
Drives: Toyota GT86
I will start and 10 and check for leaks.
08-17-2023, 02:56 PM | #7 |
Barred
Drives: My18 wrxsti My19 brzts
Wait until my Flex capacitor hits 88
The Following User Says Thank You to gen3v8 For This Useful Post: | Ultramaroon (08-17-2023) |
08-17-2023, 02:58 PM | #8 |
Drives: Crapcan
It should be around 1 ftlb depending on how you seal it. You don't want to get it too tight and damage it or pull threads. I know here at work 1/4npt brass in aluminum we do 18 in-lb. It's tapered so it locks up quick without much torque.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | autoracer86 (08-17-2023), soundman98 (08-17-2023) |
08-17-2023, 03:27 PM | #9 | |
chicken tonight
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | gen3v8 (08-18-2023), soundman98 (08-17-2023) |
08-17-2023, 04:21 PM | #10 |
Drives: Toyota GT86
1ft pound ?? Just 1 lol I think 10 is the lowest my tq wrench goes lol
08-18-2023, 11:25 AM | #11 |
Drives: Crapcan
If you go off the chart I linked, it is 2-3 turns past finger tight with sealant. I have in-lb torque wrenches for things like fittings.
08-18-2023, 12:50 PM | #12 |
Dismember
Drives: 2013 Red Scion FR-S
The Following User Says Thank You to EAGLE5 For This Useful Post: | Ultramaroon (08-18-2023) |
08-18-2023, 01:08 PM | #13 |
Drives: Crapcan
Aluminum and brass springs are very limited use. Brass isn't uncommon as a spring but it has to be heavily alloy'd.
08-18-2023, 03:33 PM | #14 | |
chicken tonight
Similar Threads | ||||
Kobe Steel | Joystick | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 11-06-2017 06:04 AM |
Stainless steel header vs mild steel header interest | mav1178 | Engine, Exhaust, Transmission | 18 | 03-06-2017 08:23 PM |
FS: gold brass knuckle shift knob | 86design | Interior Parts (Incl. Lighting) | 11 | 01-28-2013 05:30 AM |
Steel wheel | Silp3 | New England | 9 | 01-24-2013 10:14 AM |
