Drives: GR86
Driving at the limit and slip angle
Is it possible to describe using words how one would feel that they are driving at or near the limit? How do you “feel” a slight 5-8 degree slip angle is generated on all 4 wheels?
The way I drive I can feel that if I get on the gas a bit more I am going to get power oversteer, if I turn the wheel in a bit more the car is going to understeer, if I lift mid corner a bit too much back end starts to come around. Which kind of means I am at the limit, my lap times are nowhere near the limit though. I currently run 2:08 at Buttonwillow on a stock gr86 with half spent 225/17 falken 660s and carbotech xp12s. I think the limit for this set up should be close to 2 minutes since I have seen under 1:58 on cars with coilovers, bbks and 255s. Last edited by andyk5; 09-07-2022 at 07:59 PM. |
#2 |
Drives: '13 FRS - STX
Street tires should be squealing at 10/10ths, if they’re screaming you’ve gone too far and if they’re dead quiet unless the times back you up, odds are you’re under the limit.
The best word I can think of to driving at the limit is it feels a little “unglued” |
#3 | |
Bold: drive more efficiently The time means nothing without a reference point. Have you considered getting coaching? |
#4 | |
Drives: GR86
I worked with some instructors at the track days however it was not super helpful to be honest. Tightened up my lines a bit and showed some corners where late apex is faster. Actually having the coach drive his car and me in the passenger seat was more useful as I felt some forces in the car that made me realize I can push a lot harder and brought down my laptimes 5-6 seconds instantly in my own car. I would love proper coaching but its super expensive, schools are also multi thousands of dollars for a weekend. I bought Ultimate Speed Secrets book by Ross Bentley and reading through that right now. Have a garmin catalyst and thinking about sending some of my data out to someone who knows what they are doing to give me some pointers. Last edited by andyk5; 09-07-2022 at 08:15 PM. |
#5 | |
Coaching is too expensive, but you bought a catalyst? Why is lap time of such importance to you? Do you want to "go fast" or "learn how to drive"? While the two are related, time has little to do with driving skill, but fast will come naturally with the skill. Some things to really think about, because you can always purchase a lap time, but you aren't going to learn to drive well on your own. I'm willing to bet you'll get more out of one solid coaching session than you will in 5 or even 10 track days on your own with the tools you have now. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#6 |
Drives: '23 GR86 Neptune PMT
My track experience is all FWD aside from some Autocross in a BRZ, but traction circle is traction circle.
I have found at the very limit of grip there is a distinct transition where the tire begins to slide across the surface of the tarmac, and the car almost starts to feel as if is floating a bit. The steering gets lighter, and in that moment you have to be very aware of which way your front tires are facing, as if you lose a little speed and the tire regains grip, it will do so quite abruptly. You’ll often see very fast drivers often making quick steering corrections mid corner - that is an attempt to keep the tire right on that edge of grip and the car pointed in the right direction. In an ideal world, you’re entry speed and steering input would be so perfect that you would effortlessly slide at the tiniest angle around the whole corner without having to make any steering corrections - of course we are only mortal though and staying on that limit is extremely difficult. I would recommend a half or full day driving clinic, the guys at Fast Sideways operate in your area and seem to have a great reputation. If you don’t want to spend, look for an open Autocross day that will allow you to run lots of runs. For example SpeedSF hosts days at Sonoma where you can do 30,40,50 runs even on the skid pad and get tons of practice. But being comfortable feeling the edge of the traction circle and staying there will be a huge boon to your lap times. I plan on doing so very soon with my new GR86 to reorient myself to RWD. FWIW, i did about 20 track days in my MK7 GTI, and ran 2:02 Thunderhill East, 1:25 West and 1:44 at Laguna on street tires. I am by no means anything beyond an amateur driver but felt I had pretty good control on the grip limits of that car. |
| The Following 2 Users Say Thank You to Will_ For This Useful Post: | andyk5 (09-07-2022), soundman98 (09-07-2022) |
#7 | |
Drives: GR86
Keeping the car and the track the same with 10-20F variation in temperature, my only ways of measuring if I am getting better or not are faster lap times, or doing the same laptime but smoother, without wringing cars neck, banging through gears, super hard downshifts, and destroying tires/pads. As far as coaching, I agree 100% with your point. Coaching that I’ve found were , as I said on my original post, either free/cheap and not very useful or super expensive like fly the guy out to the track, pay for hotel and pay for his time kinda of deals. I guess I can try to look for opportunities in between the two. I’ve done 12 ish track days with the catalyst so far, bought for $899, amortization is getting close to transponder rental. Would coaching make me a better driver than garmin telling me to take the next right a bit faster this time around…yeah probably but was looking for a laptimer anyways so went with it |
#8 | |
I don't think I'd call the GR86 underpowered. If you're not flat almost everywhere, it's definitely not underpowered, right? Have you considered 86CUP? I offer heavily discounted coaching on 86CUP days. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | GrandSport (07-11-2023) |
#9 | |
Drives: GR86
In the meantime I signed up for alfa club drivers education at sow this weekend. 2 days, 6 hours each, 2+2+2, classroom, track, skidpad. $299 for 2 days, seems like a great deal since a track day pretty much cost close to that. Why do you think I should sell garmin? Is it that useless? To be honest I have not gotten much from reviewing my own sessions… Edit: I checked it out and looks great. I guess you are mike from the video on the 86cup site. Can’t do Oct29 but I might make it to Chuckwalla, though never been there. Stock gr86 with falken 660, pads, fluid, top hats and camber bolts seems like 1.5 second handicap and 1 points on the stock class? Last edited by andyk5; 09-08-2022 at 01:55 AM. |
#10 |
AutoX-10/10ths every run
IMO, Getting a feel for when the car is in the sweet spot of the slip angle requires:
1) Getting a feel through the steering wheel when the car is just barely responding to steering inputs without understeering 2) Getting a feel through the chassis (via your arse/body) when the rear end is just barely maintaining grip 3) Getting a feel through your internal equilibrium about if your body is experiencing subtile shifts (increase/decrease) in G forces 4) Using your vision to determine if the car is maintaining the intended trajectory through a turn 5) Experience in 1-4 Coaching will definitely help you recognize 1-4, but you'll need seat time to perfect them. B
| The Following User Says Thank You to whataboutbob For This Useful Post: | DarkSunrise (09-08-2022) |
#11 |
Wheels for Brains
Definitely read Speed Secrets by Ross Bentley.
The limit is different for everybody, and it will also differ based on your technique and driving style. The limit is hard to describe, but in a way, you will be on the edge of control. But don't mistake being at your personal limit to be the same as being on the absolute limit. It's good that you can feel the car at the limit. The next step is to figure out if what you are doing for a specific corner or series of corners actually minimizes your lap time. The absolute drive combines the best line with proper technique and driving at the limit. More than understanding what to do, you need to understand why. So, if you're trying to aim for the times that 86 class top drivers and record holders have, the best way to learn is compare your driving to theirs. https://www.86cup.us/records/ This can be done via video, with data, or both. If you're not ready to review and analyze data, devices like the Catalyst and Aim won't be very useful. If you're more receptive to lessons or interactions, this is where coaching and and being in the car with others can help. Even racing sims are excellent for this. You get tons of seat time to experiment with zero risk of wrecking when you experiment with racing lines and the limit. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | andyk5 (09-08-2022) |
#12 | |
If all you wanted was a timer, the AIM is already cheaper anyways, and has more timing functionality. Your car is already street class. Stock class is literally for nearly stock cars, not cars prepared like yours. |
#13 |
Drives: 2022 GR86 Premium Track bRed
You can probably find all this in speed secrets - I haven't read the book but I spoke with Ross recently and have my own expertise here
It's easy to saturate tires, it's hard to drive right at the edge of the traction circle, which is where the peak grip is. If you're turning your wheel more and more and more and getting no more rotation, it's because you're already past the peak - no matter how far you turn the wheel the tire is gonna generate the same amount of force. Unwind the wheel. If you're spinning your rears but you don't wanna spin your rears, lift a little. If you're trail braking but somehow still understeering, lift off the brakes or unwind the wheel. If you're getting a lot of power oversteer, you got back to the gas too fast while the car is still rotating. This is all improved with seat time. Eventually you start to understand how to maximize vertical load on the axle you care about - brake or lift to shift weight forward and give front axle more grip potential. hit the gas to shift weight backwards and straighten the car out. In the below plots, Fy-SA is lateral grip, you can see the peaks increase with load increases (going from blue to red is higher vertical load). Same with drive/brake on the Fx-SR (slip ratio) plot. Bigger peaks = bigger friction circle. Notice also, that the force drops off after the peak. ![]() Side note I've heard that the falkens heat cycle out quickly, way before tread is fully worn. |
| The Following User Says Thank You to andys_garage For This Useful Post: | whataboutbob (09-08-2022) |
#14 | |
Drives: '13 Whiteout
More seat time uncoached can just lead to the solidifying of bad habits. If you can’t afford or set up a coaching session try sending a lap to Dion at Blayze Coaching. Better even if you can send data also. Really helped me at Laguna. Nothing Beats 1 on 1 in the car though. |
| Safe oil temps for daily driving and spirited driving off the track? | MilkyWitness | Engine, Exhaust, Transmission | 15 | 06-12-2019 09:21 AM |
| First time driving manual, some questions after one month of driving | kyto31 | Engine, Exhaust, Transmission | 10 | 06-24-2018 11:57 AM |
| Slip Indicator & ABS light turned on during highway driving... | Pwolf | Issues | Warranty | Recalls / TSB | 24 | 01-15-2018 12:52 PM |
| Rev limit oft | Dragon780 | Software Tuning | 4 | 06-15-2017 11:00 PM |
| Slip angle and car control | CSG Mike | Tracking / Autocross / HPDE / Drifting | 28 | 06-12-2014 08:57 PM |
