Old 09-01-2015, 06:19 PM   #1
phongtphan21
Drives: 2013 Fr-s
Start up issues?
Hey guys. I recently purchased my fr-s 2k13 a few months ago and I'm came to an issue when I start up my car, it doesn't happen often but once in a while it wouldn't want to start. Doesn't crank or make any noises. The lights and stuff comes on but it won't start.
Would you guys know anything about this? I took it to Toyota and they said everything was fine, took it in twice.
Any feedback will be great. Thanks.
phongtphan21 is offline   Reply With Quote
Old 09-01-2015, 06:34 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Is it a manual? There's a button that the clutch engages in order for the car to start, and if that's stuck or broken, it can lead to this sort of behavior.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
dj2020 (09-02-2015)
Old 09-01-2015, 07:32 PM   #3
Struckbylitenin
Struckbylitenin's Avatar
Drives: 10 Series FR-S
mine has done that; tightening the battery terminals fixes it
Struckbylitenin is offline   Reply With Quote
The Following User Says Thank You to Struckbylitenin For This Useful Post:
ScionFR-S (09-10-2015)
Old 09-02-2015, 02:41 PM   #4
dj2020
I'm literally sitting at the dealership looking to get this fixed as well. The dealer believes it's the clutch neutral switch as mentioned above. If the switch is going bad, I believe you'll get intermittent starting issues because the ECU doesn't know the clutch has been depressed. My push button start simply cycles between off, ACC, and on without car firing up.
dj2020 is offline   Reply With Quote
Old 09-02-2015, 03:09 PM   #5
Yep, I’d go with a funky neutral switch or the battery is weak.
Old 09-02-2015, 09:50 PM   #6
S84kam
S84kam's Avatar
Drives: FBRZS
When I purchased the car during the winter it did that. I switch out my batteries to the optima and never had another issue. Hopefully I can update this post for the next winter to see how it goes
S84kam is offline   Reply With Quote
Old 09-03-2015, 05:44 PM   #7
dj2020
Well, the dealer didn't get to my car yesterday so the clutch neutral switch is being swapped out today. However, the service advisor said that there is no guarantee that this is the problem because I am not throwing any error codes for this switch. He then proceeds to say modded car, aftermarket flash, supercharged, etc. The dealer is probably just covering their butts in case this doesn't fix the problem. Anyone else with JRSC Carb Tune where the car does not start with the push button intermittently? Anyway, this can even be a tune issue? I'm doubting a bad clutch neutral switch would even throw a code. @CSG Mike: curious to know what you think as well.
Old 09-03-2015, 06:45 PM   #8
CSG Mike
CSG Mike's Avatar
I've not heard of it happening.
Hot starts have never been an issue with the JRSC and good tune. If you're on a custom or e-tune, then I can't speak for that specific setup.
Old 09-03-2015, 07:44 PM   #9
dj2020
Just CARB tune. Car will not start intermittently. Doesn't even crank. Just cycles between ON, ACC, and OFF as if the clutch isn't depressed. Doesn't matter if hot or cold start. Anyway, I still think it's the clutch neutral safety switch. I'll get the car back tonight and let you guys know if I still have these intermittent starting problems.
Old 09-10-2015, 02:20 PM   #10
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
tighten terminals happened to me too, I just hand tightened them and the car would sometimes start or sometimes just go dead
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 09-10-2015, 02:38 PM   #11
dj2020
So it's been a week since the neutral clutch safety switch has been replaced and I have not had any intermittent starting issues when I clutch in and use the push button start. I'm cautiously optimistic that was my problem and it's been fixed.
Old 07-19-2023, 07:24 PM   #12
dynarun55
Drives: 2015 midnight blue limited edition.
Looks like it has been a while, but I'm in the same boat now. Was that the actually fix ? Now that it's been more than a week
dynarun55 is offline   Reply With Quote
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 10:57 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Keyless Entry and Start-up issues taiguochin BRZ First-Gen (2012+) — General Topics 27 01-21-2013 11:15 AM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
