Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-12-2021, 01:04 AM   #1
Jucostud
Rookie
Jucostud's Avatar
Drives: '22 BRZ Premium MT6
***2022 BRZ on the Vorshlag scales***
Took my car to Vorshlag tonight so they could get some measurements, look the car over, and weigh it...
2744 lbs with 1/4 tank
Here's their official photos from looking it over
Jucostud is offline   Reply With Quote
The Following 14 Users Say Thank You to Jucostud For This Useful Post:
alphasaur (11-12-2021), beltax90 (11-12-2021), DarkSunrise (11-12-2021), des (12-18-2021), DocWalt (11-15-2021), dpfarr (11-12-2021), Grif (11-12-2021), JusTheG (11-12-2021), Panda Grahams (11-12-2021), Quagmire (11-12-2021), Rcode (11-12-2021), RToyo86 (11-14-2021), Stonehorsw (11-12-2021), WC-BRZ (11-13-2021)
Old 11-12-2021, 01:33 AM   #2
alphasaur
friendly
Drives: 17' 86
Wonder if gen 1 exhausts will fit
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-12-2021, 02:43 AM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
Unless hanger placement changed (doubtful) the Gen 1 exhaust fits. Aftermarket headers fit fine too.
PulsarBeeerz is offline   Reply With Quote
The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post:
DocWalt (11-15-2021), FrickingReallySlow (11-12-2021)
Old 11-12-2021, 09:42 AM   #4
86-75309
Drives: Until recently, a 2020 Hakone 86
Am I seeing 56% of the weight on the front end? What happened to the 53/47 distribution they've been touting?
86-75309 is offline   Reply With Quote
Old 11-12-2021, 09:51 AM   #5
Pete
Pete's Avatar
Drives: 22 BRZ
1/4 tank of gas and no jack in the trunk. Gas tank is in the rear of the car.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 11-12-2021, 10:29 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
That was a lie... It's been a pretty craptastic 55/45 with a full tank and driver from the beginning. I've gotten mine to 53.5/46.5 with 5 lb. battery, 2-piece front rotors, catless header, and empty washer fluid reservoir taking 50 lb. off the front. Seems like the new one might be slightly nose-heavier. DOH!
They should make a 2-seat version with rear wheels shoved a good 10" forward, shorter wheelbase, lighter weight, stiffer chassis, and ~50/50 distribution...
Old 11-12-2021, 11:28 AM   #7
PulsarBeeerz
Oh lord you said the magic words and he appeared to come complain.lol
The Following 3 Users Say Thank You to PulsarBeeerz For This Useful Post:
alphasaur (11-12-2021), DocWalt (11-15-2021), WolfpackS2k (02-21-2022)
Old 11-12-2021, 01:01 PM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'ma hafta saw this car in half and graft it back together with a section removed
Old 11-12-2021, 03:15 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
https://www.ft86club.com/forums/show...23#post3480023
The Following User Says Thank You to timurrrr For This Useful Post:
Old 11-12-2021, 05:43 PM   #10
mazeroni
Drives: 2013 Scion FR-S Series 10
Does weight distribution matter as much given the placement of the drivetrain? If it was sitting higher, I would expect the car to feel more like any other FWD car. Nose heavy and prone to understeer, squat, and dive.
From my own experience, and knowing how well the car does in autocross and other events, the lower CG seems to mask those issues and the car overall feels light at the front.
mazeroni is offline   Reply With Quote
Old 11-12-2021, 05:46 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
It matters. Particularly if you want to add power, but even at stock power levels, it doesn't help that the outside front is relatively overworked and the outside rear relatively underworked. Overall feel is still quite good, but even with a lot of front camber and rear-biased spring stiffness, I'd like mine to "point" a bit better and to abuse the outside front a bit less...
mazeroni (11-12-2021)
Old 11-12-2021, 06:01 PM   #12
LanceLane174
Drives: 2022 BRZ Limited WRB, MT
Put a spare tire in the wheel well and fill the tank up. Problem solved.
LanceLane174 is offline   Reply With Quote
The Following User Says Thank You to LanceLane174 For This Useful Post:
mike2100 (04-29-2022)
Old 11-12-2021, 06:08 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
I already do that to meet weight for my time trials class! Sometimes add a stock front brake rotor on top of the spare! Still no better than ~53.5/46.5 even with 5 lb. battery, 12-lb. lighter front rotors, empty washer reservoir, and catless header (-50 lb. off the nose of the car).
soundman98 (11-13-2021)
Old 11-12-2021, 07:10 PM   #14
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Higher center of masses = more longitudinal weight transfer when accelerating or decelerating, meaning the car is less prone to understeer when trail braking.
The first time I drove an STI vs BRZ one after another on a frozen lake, the BRZ understeered when I carried too much speed into a corner, whereas the front of the STI was grabbing, and the car was turning in a lot more confidently.
Squat/dive is also a function of spring rates, wheel base, anti-squat/anti-dive suspension geometry, etc.
Corner Scales? Campo Arizona 1 02-14-2022 05:58 AM
Vorshlag BRZ/FR-S/86 Camber Plates for KW v3 AWE46M3 Brakes, Suspension, Chassis 0 06-24-2020 09:58 AM
OFT - Example alternate maps for AT, 98RON, E85, MAF Scales Wayno Software Tuning 562 06-24-2017 05:36 AM
Vorshlag LSX kit cf6mech Engine Swaps 749 12-06-2016 05:21 PM
any one sell vorshlag?! FISHBURGLAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-20-2015 02:49 PM
