| Software Tuning Discuss all software tuning topics. |
Drives: '15 GT86
Kindly I need a xml file for BRZ Cal ID: ZA1JA02K , for ECUflash. since I can't read the files I pulled from my car and gives me "Uknown ROM Image Error" RR is working great. Unfortunately, I tried searching every place, but no good. Please, someone help!
2015 GT86 AT |
#2 |
Drives: Toyota GT86
You can use a ZA1JA01I rom instead.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#3 | |
Drives: WRB BRZ
You can make a fleash definition for any rom Creating a bare bones definition for flashing a ROM with no existing definition Useful if your car has old ROM not defined and you want to try update and be able to flash back to old ROM or you have pulled really new ROM from a car and no definition yet. Open the rom with no definition in Ecuflash, it will tell you it does not have a definition, do you want to create one. You press yes, and then click on from scratch. Then you choose SH72531 under memory module, and Subarubrz flashing method. The unique identifier is at 8000 and 8 bytes long. Fill the rom info in with the year, model etc. - not critical that this is accurate if you're just using it to flash. Click Finish, and when you're back in Ecuflash, click on file, and 'Save Models'. This should allow you to flash ROM but not edit as no tables defined. |
#4 |
Drives: WRB BRZ
Full info see here
https://www.ft86club.com/forums/showthread.php?t=62332 or laternativly use the A01I its compatable as the guy above stated |
#5 |
Drives: '15 GT86
Thanks guys for your inputs.
So, do you mean I can flash an old rom like ZA1JA01I on ZA1JA02K ECU? without any problems? since they are compatable. Plus, I have tried creating one from scratch, but it work as you said. it won't read tables. |
#6 | |
Drives: WRB BRZ
i thonk there is full definition for A01K you could try that or best would be jist switch to the A01I rom and definition its compatable with your 2015 auto trans car A01I is well definied rom and will work fine in your car as a substitute rom |
#7 | |
Drives: '15 GT86
Thank you! I really appreciate your help guys! |
#8 | |
Drives: WRB BRZ
yes you can always reflash the olf A02K if needed |
| Tags |
| brz, ecu def, ecuflash |
| Look for the ZA1JA03N complete RomRaider Editor Definition definition file. | nerve86 | Software Tuning | 13 | 06-03-2022 07:42 AM |
| ecuflash definition file help | Plumpkibbles | Software Tuning | 1 | 10-13-2018 05:19 AM |
| Definition of rice? | Hot Lava | Off-Topic Lounge [WARNING: NO POLITICS] | 42 | 05-30-2014 03:41 AM |
| AS1 Definition? | nixeighty6 | Scion FR-S / Toyota 86 GT86 General Forum | 93 | 01-12-2012 01:56 AM |
