Old 01-08-2022, 05:28 PM   #1
Saskatuon
Drives: 2017 Brz
pulsing dash and headlights
Hello, so i installed the trackbox from geralds projects on my car, it just plugs into a connecter for the canbus so i wouldnt think it could really short anything out. i did remove the accessory connector for the steering wheel and replug it aswell in this time. Car gets power but wont go into accessory mode or even attempt to start. Not sure where to Start with trouble shooting this? anyone got any suggestions, Thanks.
Saskatuon is offline   Reply With Quote
Old 01-08-2022, 05:35 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
first step is to check fuses, under the hood, and under the dash, drivers-side floor board.
humfrz (01-08-2022)
Old 01-08-2022, 09:43 PM   #3
Then, after you check all the fuses, I suggest you return your system to the way it was before you started your modifications and see it runs proper.
soundman98 (01-08-2022)
Old 01-09-2022, 02:20 AM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
Pulsing lights when accessory is on typically means the battery has a low charge.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 01-09-2022, 03:22 PM   #5
Or alternator.
Or regulator.
The first step is to check voltage at the battery though.
Compelica (01-09-2022)
FR-S Pulsing Under Acceleration SuperFR-S Scion FR-S / Toyota 86 GT86 General Forum 4 11-15-2021 07:06 PM
2015 FRS pulsing at low RPM's in 1st gear ImBatman Scion FR-S / Toyota 86 GT86 General Forum 32 06-07-2019 12:48 PM
Question about dash icons and headlights/fogs/highbeams TooSlow Scion FR-S / Toyota 86 GT86 General Forum 27 06-28-2018 04:27 AM
Pulsing when Accelerating carma143 Issues | Warranty | Recalls / TSB 41 02-27-2015 09:29 PM
weird pulsing while stopped neil125 Issues | Warranty | Recalls / TSB 2 05-15-2013 12:04 AM
