Old 09-11-2012, 12:59 PM   #1
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Automatic transmission selector details?
I was wondering if anyone has any of the following details:
  • Part# to the Automatic Trannmission Selector
  • A wiring diagram to the harness which connects to it
  • Pictures of the connector harness or the pins under the selector itself
My car is currently in the shop with the VVT CEL issue. While I don't have access to it, I wanted to start working on a process to reverse the (+) with the (-) when the selector is set to manual.
@Art_Mighty is offline   Reply With Quote
Old 09-11-2012, 02:11 PM   #2
P&L Motorsports
P&L Motorsports's Avatar
Drives: '13 Turbo BRZ (AT) & '13 FRS
Just reverse the two wires. I have it done on ours works great!
P&L Motorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to P&L Motorsports For This Useful Post:
@Art_Mighty (09-11-2012), CircuitJerk (09-11-2012)
Old 09-11-2012, 03:32 PM   #3
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Is it literally THIS simple? ;take off shift boot, pop off selector with a screw driver, reverse the wires is connected to the (+) switch and the other to the (-)?
...or is there a harness I'm cutting into?
Old 09-12-2012, 11:14 PM   #4
P&L Motorsports
Yes its pretty simple! Once you take off the trim piece there will be 2 black wires and two white wires going to the little momentary switches. just reverse them. Or if you want take the actual shifter apart and reverse the momentary switch location. Be careful taking apart the shifter though a little pin will fall out and its hard to put back in.
Lmk if you need anymore help.
Paul
Old 09-17-2012, 01:24 PM   #5
soulstice
Drives: SWP BRZ LTD
i don't have the car yet but am very interested in doing this.
Where is the location of the pin that you have to watch out for that might pop out?
soulstice is offline   Reply With Quote
Old 09-17-2012, 01:44 PM   #6
slawdio
ON SALE
Drives: '13 WRB BRZ Premium
Do you want to reverse the paddles? Or are you trying to reverse the (not sure if the auto's have one) slap-stick?
I thought the right-paddle-up, left-paddle-down was pretty intuitive?
slawdio is offline   Reply With Quote
Old 09-17-2012, 01:48 PM   #7
Kurenai
Drives: 2013 Scion FR-S Hot Lava 6AT
We're looking to reverse the stick, not the paddles.
Kurenai is offline   Reply With Quote
Old 09-17-2012, 07:22 PM   #8
proficience
proficience's Avatar
Drives: Velocity Orange 86 GTS M/T
DIY please!
proficience is offline   Reply With Quote
The Following User Says Thank You to proficience For This Useful Post:
shishand (10-29-2012)
Old 09-18-2012, 03:47 PM   #9
P&L Motorsports
Here is a short video of the shift pattern reversal. Forward is downshift (-) back is uppshift (+).
Sorry for the quality! I was trying to film,steer,and shift all with one hand. LOL
[ame="http://www.youtube.com/watch?v=h9Izop25xaA"]Shifter pattern reversal - YouTube[/ame]
Enjoy!
I will try to do a DIY soon!
Paul
The Following 4 Users Say Thank You to P&L Motorsports For This Useful Post:
karbon (09-18-2012), nix (10-02-2012), proficience (10-04-2012), shishand (10-29-2012)
Old 10-04-2012, 09:29 PM   #10
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
I am interested in doing this as I feel the alternative setup is more intuitive.
My question, does anyone know if it is possible to swap the actual + and - symbols? I'd imagine they are fairly permanently fixed, but it would be nice to have them match the altered transmission.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 10-04-2012, 09:48 PM   #11
proficience
The labels are in the plastic. The easiest way is to get two stickers and cover them up, but with a little more effort you could do something more permanent.
Old 10-13-2012, 05:58 AM   #12
Hayate
Drives: Scion FR-S
Help with switching the wires!
I am trying to figure out how to re-wire the black/white wires leading to the contacts on the momentary switches. I removed the shift boot trim and was trying to figure out exactly how to gain access to the momentary switches so that I can pull out the wires and switch them around. Has anybody done the re-wiring and switched the wires? How do you remove the white plastic housing that is covering the momentary switches? Any help would be greatly appreciated!
Hayate is offline   Reply With Quote
Old 10-18-2012, 09:54 AM   #13
pozer
pozer's Avatar
Drives: 13 FR - s
Send a message via AIM to pozer
The two black wires run to a plug at the front of the shifter that can pop up with a screwdriver but cant get it out of that area and don't want to pull on the wires.
pozer is offline   Reply With Quote
Old 10-19-2012, 03:46 AM   #14
Hayate
Drives: Scion FR-S
Thanks for the tip. It looks like I have to remove the center console in order to be able to access the plugs for the black wires. I was thinking that I would only have to remove the shift lever cover trim. I couldn't see the plugs for the wires with just the shift lever cover trim removed. I guess I'll be able to see the wire plugs once I remove the center console.
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 10:42 PM
Which transmission do you have ? Manual or Automatic ? PRO Import Tuners Engine, Exhaust, Transmission 14 08-24-2012 10:21 AM
Yes, the automatic transmission is that good Mburolla Member's Car Journals 4 07-30-2012 05:48 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 04:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
