Old 01-05-2021, 02:50 PM   #1
touko
Drives: 2017 Toyota 86
Auto-off dome light
This is the second time I've drained the battery with leaving the dome light on my 2017 86. Does anyone know if there is a good way to make this turn off after a while?
What I noticed btw is the headlights have auto-off when on auto position, where simply locking with remote will trigger a timer, and another press to turn off the lights. I wonder if there are some signals that can be used for controlling dome lights..
touko is offline   Reply With Quote
Old 01-05-2021, 03:06 PM   #2
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Dome light can be put on Door mode. Move/slide the switch to Door and you won't have any issue after locking the car as it will switch off after like 10 seconds.
Also change the bulb to a led one.
Problem solved.
Thefalls is offline   Reply With Quote
The Following 8 Users Say Thank You to Thefalls For This Useful Post:
DarkPira7e (01-05-2021), HKz (01-05-2021), ichitaka05 (01-05-2021), Jdmjunkie (01-05-2021), ls1ac (01-05-2021), soundman98 (01-05-2021), spike021 (01-05-2021), x808drifter (01-05-2021)
Old 01-05-2021, 03:34 PM   #3
9walker
9walker's Avatar
Drives: Toyota 86
Led is your answer. I left it on the whole day then drove away like nothing happened.
Sent from my SM-G975F using Tapatalk
9walker is offline   Reply With Quote
Old 01-05-2021, 05:30 PM   #4
touko
Problem solved.
Mine is on Door mode 99% of the time. The problem is when I switch it to On for something then forget to switch it back to the Door before I get out.
I’ll look into LED lights regardless. Thanks for the suggestion!
Old 01-05-2021, 05:47 PM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This is what keeps AAA in business. Try your best to be cognizant, but we all do it.
Old 01-05-2021, 11:13 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
mine doesn't work that way. if i left it on, the battery would definitely be dead.
there's cheap low power led, and there's expensive led
Old 01-08-2021, 10:14 AM   #7
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
"All"
First thing I've done in my last few cars is turn the dome light off. It's attracts bugs in the summer time and I hate bugs more than anything.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Dome light nguyen.tommie Cosmetic Modification (Interior/Exterior/Lighting) 1 11-05-2019 11:52 AM
Underglow/footwell light controlled by door without using dome light or door switch pcguru2000 DIY (Do-It-Yourself) Guides 5 06-17-2018 12:09 PM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 10:39 PM
Dome light very low power???? lbroskee Electronics | Audio | NAV | Infotainment 2 03-15-2014 03:03 PM
