My husband took our car to work yesterday and came home and everything was working fine. I got in the car last night to go get some dinner and when I turned the key in the car would not start, there was no clicking or attempt to turn over, just nothing happened. The dash lit up and the headlights came on as normal, but the car just would t start. Tested the battery and it’s near 100% - any suggestions?
#2 |
How did you test the battery and how close is "almost" 100%?
#3 |
Are used a battery tender and The light was green which means it doesn’t need to be charged any longer
#4 | |
You should get the battery tested properly at an autoshop. Most auto retailers can do it. There is no sense looking further until it is 100% confirmed that the battery is fine.
#5 |
Rust bucket enthusiast
Is this an automatic or a manual car? Are you holding the clutch pedal down 100%?
#6 |
Automatic, no clutch
#7 |
Car is in park? I don't know if you have to have the brakes down or not to start it, but also try having your foot on the break. I'm assuming it's not push to start. Try putting a booster pack on it and see what it does. Just as @Tcoat said, it's likely that the battery is your issue. There are only so many things that have the symptoms you've described |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tcoat (11-11-2020) |
#8 | |
Not like that guy that put in a new starter, alternator, all the fuses and cables and THEN checked the battery!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkPira7e (11-11-2020), x808drifter (11-12-2020) |
#9 | |
It's a classic case of loving something too much; you assume the worst at every turn. I know too many people who can't get heat to work in their car at the onset of fall and think they need a new heater core or something absurd. "Did you check your coolant level?" "uhh not yet..." |
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | soundman98 (11-11-2020), Tcoat (11-11-2020) |
#10 | |
#11 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
| The Following 2 Users Say Thank You to LimitedSlip For This Useful Post: | soundman98 (11-11-2020), x808drifter (11-12-2020) |
#12 |
Do you have a test meter?
If not get one {harbor freight $5} Put the leads on the battery posts and have someone try to start it. If no change then move to the wires leaving the battery area. If voltage is there then the battery connections are good, try starting again. If no drop in voltage then it gets more complicated. Starter circuit, Solenoid or starter. Always start with the simple first. |
#13 |
Master Collaborator
My guess is that he installed an anti-wife device yesterday before he came home from work.
| The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post: |
#14 |
| Tags |
| battery, dead, not sure |
| Help car not starting! | nickl474 | Issues | Warranty | Recalls / TSB | 6 | 10-31-2019 06:54 PM |
| car not starting | Ayeitsjayson808 | Issues | Warranty | Recalls / TSB | 12 | 04-16-2016 08:21 AM |
| starting out | dmitri93 | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-11-2014 01:06 AM |
| Rev when starting ? (Possible and why ?) | Simon99 | Software Tuning | 11 | 05-22-2014 05:12 AM |
| Starting it off | e10rice | Mid-Atlantic | 93 | 03-26-2012 04:16 PM |
