Drives: 2015 BRZ
make me less dumb - how tight is too tight for brake pads?
Hey all,
Just got some custom-made track pads from Raybestos/Porterfield - they were ground from a larger pad footprint. Some I had use a file on the backing plate edges to get them to fit in the caliper - but some are still TIGHT. With heat expansion, I'm worried that they might not move in and out as freely as they are supposed, and might drag, causing more heat, causing more sticking... etc. Should I just drink a beer and forget it? File more off so they slide in/out more easily? Thanks all. |
#2 |
Rust bucket enthusiast
They have to slide in and out freely. If they don't, you're going to run into trouble.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | slowmow (10-27-2020) |
#3 |
With the retention clips, you should be able to get them in/out readily with just a tiny bit of tension.
What's necessitating a custom-made pad? |
| The Following User Says Thank You to CSG Mike For This Useful Post: | slowmow (10-28-2020) |
#4 |
Drives: Nevermorange FRS
You want some slop and for racetrack I don't recommend retainer clips. I've had more hangups and issues with retainer clips than I care to admit before I threw them all away and life was grand.
On my CRX I used to buy pads from Porterfield for an S2000 then I would use a file to remove 1 or 2mm on the end tabs to fit in my calipers. The reason for buying the S2k pads was they were larger and got me more "meat" which translates to more heat sink.
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | slowmow (10-28-2020) |
#5 | |
Drives: BRZ 2017 Pure Red, MT
Any disadvantage of running without the retainer clips? I bought new OEM brake pads for the winter (came with new clips), and I had to grind/file the backplate near the tabs because they were too tight... |
#6 |
Not in 16 years of W2W racing.
SCCA T4 - FRS
#8 |
Purist
Drives: 2013 FRS - Hot Lava
I had to grind down the corners of the WinMax W3 pads I bought. Maybe 2-3mm on one side. You should not need tools to put in or take out pads. They sort of "click" into place. Not really, but very very little tension.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#9 |
Thanks
Take out old retaining clips. Clean any rust on the caliper bracket with a file before installing new clips. That is usually what causes this issue. But sometimes aftermarket pads are not perfect. Just make sure rust isn't the culprit first
| The Following User Says Thank You to ZionsWrath For This Useful Post: | slowmow (11-03-2020) |
#10 |
Purist
| The Following User Says Thank You to Westen86 For This Useful Post: | slowmow (11-03-2020) |
| Clicking when turning tight | Impureclient | Issues | Warranty | Recalls / TSB | 7 | 06-23-2020 06:36 AM |
| hand brake boot too tight | akash_ | Issues | Warranty | Recalls / TSB | 25 | 11-13-2014 02:05 PM |
| Tight Fitting Brake Pads | NightRaven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 10-29-2014 03:13 PM |
| NAV unit shuts off when doing tight turns | ReaperX43 | Electronics | Audio | NAV | Infotainment | 2 | 09-24-2014 10:32 PM |
| Fuel Lid Tight or Loose? | JiB | Issues | Warranty | Recalls / TSB | 18 | 09-20-2012 01:50 PM |
