| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: TRD R.S. 1.0 FRS
Putting back the transmission. Please help
Did a clutch change and all that. Hours and hours the transmission will not go back in. No matter how hard we try. Im spinning the driveshalf from the rear of the transmission. And its in 4th gear so still nothing it gets stuck on the studs on the bottom.
Theres no wires. The fork and the TOB seem to be fine. Dont understand Update: We got really close but the top had about a 1inch gap from meeting and bottom had about 1/2 gap from meeting. Dropped the trans back down. Used the alignment tool to check and it only went in about 1 inch. We took out the clutch and noticed marks on the grooves/splines in the clutch. And then noticed fractures. 8 of them to be exact. Ughh Lesson learned. Gonna use the old one sinche i still got 65% of it still on it. Gonna give it a go tomorrow morning! �� Update again: success!!! we finally got the trans in and everything. we pulled the clutch and all that and reinstall with the alignment tool again. thanks for all the help and advice! you guys rock! Last edited by airrick; 04-27-2020 at 01:03 PM. Reason: update |
#3 |
#4 |
Someone? Please? For the life of my i cant. 2 days nothing.
#5 |
did you use the plastic alignment tool? it will flex. if so loosen up the clutch and raise it a little.
#6 |
Drives: Subaru BRZ
Did you jack up the front of the engine?
#7 |
[insert cool phrase here]
Drives: BRZ Premium
When I did my clutch it was almost flush till half an inch.
I tried everything. What I eventually did was put in the bolts and slowly and evenly tightened them like lug nuts. Sure enough it sat flush. Zero problems afterwards.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#8 |
What you describe sounds like it is not going into the pilot bearing. You may half to back off the bolts for the clutch and recenter the tool by moving it around and slowly resetting the bolts. The plastic tools are not great.
#9 |
Drives: 2016 brz
Hey man pm on here I’ve recently pulled my trans out like 2-3 times I’ll send you my number and can give you some tips on what to do maybe I can catch what ur doing wrong
#10 |
#11 |
Both guide pins are in place? If one fell out you'll never get it lined up.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | gravitylover (04-27-2020) |
#12 |
#13 | |
I used the plastic alignment tool. I had to put back everything since i wanted to double check. Ill look at it again tomorrow Yea i assumed this was it. Ill try it tomorrow morning. I did try it that. But ill try it again. |
#14 | |
https://demos.starbase7.net/t3Portal...01P1500UX.html
| The Following User Says Thank You to Ultramaroon For This Useful Post: | SuperTom (04-26-2020) |
| FS: 2016 FRS Engine/Transmission 40 k miles Invidia cat back | sokol | Engine, Exhaust, Bolt-Ons | 1 | 08-28-2019 10:55 PM |
| HKS full manifold-back exhaust for Automatic transmission? | UNREAL | Engine, Exhaust, Transmission | 14 | 08-15-2019 11:37 PM |
| Thinking of putting back stock exhaust | frsqc | Engine, Exhaust, Transmission | 31 | 07-31-2018 08:55 PM |
| Putting stock FP back on. Heat shield? | Tysoncrosby21 | Engine, Exhaust, Transmission | 4 | 01-02-2017 04:02 PM |
| Can't get rid of TPMS light after putting OEM wheels back on | customfab87 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 10-23-2016 04:54 PM |
