Old 04-22-2020, 03:28 PM   #1
glutenpoops
glutenpoops's Avatar
Drives: 2015 Subaru BRZ Limited
OFT E85 - Push Button Cold Start
Hey guys,
I switched over to E85 last week with OFT. I downloaded and flashed the off-the-shelf v4.03 Stage 2+ e85 for ZA1JD00C. I just have a cat-back mxp exhaust, I haven't done headers yet. I've been driving daily and I'm almost through my second tank. I made sure to let the ECU do its thing with each fill-up and once it's warmed up I've been having some fun for sure! I've been monitoring my afr and fuel trims and everything seems fine.
Last night leaving work, the car took longer than usual to turn over. Then, this morning the car didn't fully turn over and died. I had to crank the ignition twice - second time no issues. I understand that e85 burns cooler and it is common to take longer to turn over on a cold start. I read a lot of posts from years back, and I thought that the new off the shelf tunes fixed some cold start issues.
I live in San Diego and last night it was only around 59 degrees. I've heard in California for some reason the ethanol percentage is usually pretty high, but I have no way of knowing the % for sure at the station I fill up at. But I'm just assuming the ethanol percentage is high if I am having issues at 59 degrees?
I have a push button start, and it seems like the push button ignition only wants to crank for around 1 second before giving up. Is this normal? Will it fix itself? I'm a complete beginner to tuning and I really am scared to edit the tune. If I keep having issues in summer weather I might flash back to stage 1.
Anyone have any advice for me?
Thanks
glutenpoops is offline   Reply With Quote
Old 04-22-2020, 03:51 PM   #2
DarkSunrise
DarkSunrise's Avatar
It's normal - as you said, the ethanol content in CA is on the high side. It's been about 55-65 F here in the mornings and the first start of the day will usually take 2-3 attempts.
One fix is to add a gallon of 91 with every tank of e85.
Another fix would be to modify the cranking fuel injector pulse width tables, as shown in this thread:
https://www.ft86club.com/forums/showthread.php?t=131387
2022 BRZ Build
2013 FR-S Build
Old 04-22-2020, 05:09 PM   #3
glutenpoops
Thank you, I'll try a gallon of 91 with my next fill!
Old 04-22-2020, 11:20 PM   #4
steve99
Drives: FT86
Originally Posted by glutenpoops View Post
Hey guys,
Thanks
I can modify you tune so it starts way better in cold weather and few other mods
message me if your interested
Push to start button- need help Tomo3101 Scion FR-S / Toyota 86 GT86 General Forum 7 09-28-2016 07:21 PM
Push Button Start (or not) X Factor Issues | Warranty | Recalls / TSB 4 10-26-2015 10:18 AM
Sti Push Start Button brzsubarusti13 Want-To-Buy Requests 4 06-29-2015 08:01 PM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
