Old 07-15-2013, 05:07 AM   #1
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Stock Muffler Cut Open
Thanks to @Clipdat for the free muffler so I could do this. If you guys want, I'll give you more info on how you can cut it without causing as much damage as I did.
[ame]http://youtu.be/PGHc4GI5eL0[/ame]
The Following 11 Users Say Thank You to EAGLE5 For This Useful Post:
bedabi (07-17-2013), Clipdat (07-15-2013), hmong337 (07-18-2013), hunter3232792 (07-15-2013), I<3Twisties (07-15-2013), JiB (07-15-2013), Lonewolf (07-15-2013), mad_sb (07-15-2013), Marchy (07-15-2013), RehabJeff86 (07-15-2013), S84kam (07-30-2015)
Old 07-15-2013, 05:43 AM   #2
typericey
WRX to BRZ
typericey's Avatar
Is the inside of the muffler really without acoustic fibers or did you just take them out?
typericey is offline   Reply With Quote
Old 07-15-2013, 09:28 AM   #3
mad_sb
Drives: 2013 Asphalt FR-S
exactly what i was going to ask
Comments on the vid in youtube say it was empty.. not batting or filler at all..... Looks like it has a small bottle type resonator in each exit pipe.
@jsimon7777,
Thanks a ton for doing this..
Are there any block off plates or baffles on the tube inlets for the exit paths or the main inlet from the midpipe? Also, the inlet for the right hand side outlet... hard to see in the video what is going on with the pipe.. looks like it is turned down towards the floor of the can... but does it touch or is it just angled down a bit?
The Following User Says Thank You to mad_sb For This Useful Post:
EAGLE5 (07-15-2013)
Old 07-15-2013, 09:52 AM   #4
mad_sb
Without getting a better look, my first attempt at modding would be to cut out the pipe sections in yellow, then pack the areas in blue with muffler packing material.
EAGLE5 (07-15-2013)
Old 07-15-2013, 12:43 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Official first OEM muffler cut open award! I'm surprised you got to it so quickly, couldn't wait to see what was inside eh??
Looks like there's definitely some improvements to be made, can't wait to see what you end up doing with it.
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
EAGLE5 (07-15-2013), ramiram1984 (07-15-2013)
Old 07-15-2013, 12:48 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Suggestions? Shortening or lengthening pipes? baffles to aim exhaust? Sealing some holes?
Yes, I couldn't wait. Twas fun. Didn't even cut a finger!
Old 07-15-2013, 12:49 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
What would that do to the sound, ya think?
Old 07-15-2013, 01:03 PM   #8
EAGLE5
Dismember
EAGLE5's Avatar
@jsimon7777,
I'll take a look later along with higher-rez photos. The pipe is turned down some.
Old 07-15-2013, 01:03 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
It is all an evil trick.
Old 07-15-2013, 01:54 PM   #10
ramiram1984
Drives: 2016 STi DGM
Aftermarket exhaust.
Perrin.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 07-15-2013, 02:06 PM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
^^ Doesn't "get it".
I'm old and lazy
mad_sb (07-15-2013), ramiram1984 (07-15-2013)
Old 07-15-2013, 02:09 PM   #12
mid_life_crisis
Drives: FR-S 10 #103 AT
Then you obviously aren't done. Get back out there and make a blood sacrifice to the performance gods.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following 4 Users Say Thank You to mid_life_crisis For This Useful Post:
EAGLE5 (07-15-2013), FrX (07-17-2013), Marchy (07-15-2013), Sportsguy83 (01-14-2014)
Old 07-15-2013, 02:44 PM   #13
ramiram1984
I do
-2014 SSM BRZ MT
Old 07-15-2013, 03:26 PM   #14
mad_sb
would be louder due to less resistance on the path to exit but that should also mean a little more power. Ultimately i am after the best flowing quiet exhaust i can get. If you have to spend more than a 100 bucks on material and labor it gets to the point that an aftermarket unit is more attractive.
For best flow you would probably need to gut the interior and weld in a perforated y pipe to connect the inlet and outlets then pack the core with steel wool / muffler packing material.
Replace stock muffler? Pacific Auto Engine, Exhaust, Transmission 20 07-21-2014 11:38 PM
Modding stock muffler Ghost 86 Engine, Exhaust, Transmission 6 07-15-2013 05:11 AM
Keep stock muffler with other exhaust mods? jordanrw260 Engine, Exhaust, Transmission 51 03-23-2013 11:38 AM
Has anyone replaced the stock muffler with a smaller one? ScionFrsFan Engine, Exhaust, Transmission 2 02-13-2013 08:55 PM
