Old 11-17-2015, 01:12 PM   #1
kmac_brz
Drives: 14 WRB BRZ
Dome light flashes on door setting
My dome light when out on "door" just constantly flashes if I put it on "on" it stays on solid. Any thoughts?
kmac_brz is offline   Reply With Quote
Old 11-18-2015, 07:41 PM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Electrical issues are tricky. First, I have two questions:
1) Have you done anything to the electrical system recently? In particular, anything with the rearview mirror harness (e.g. BlendMount tap), changed the dome light bulb, installed an alarm system, changed anything in one of the fuse boxes (esp. the one under the steering wheel)?
2) Are any other interior lights flashing? Is the door ajar light (on the dash) staying on with the doors and trunk shut? Is the door ajar light flashing with doors and trunk shut?
theadmiral976 is offline   Reply With Quote
Old 02-28-2020, 04:03 AM   #3
FRS Justin
Drives: 2013 Asphalt FRS
Did anyone figure this out?
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 02-28-2020, 12:14 PM   #4
Get out of the archives - it was the trunk monkey messen around -
soundman98 (02-29-2020), spike021 (03-01-2020)
Old 02-28-2020, 02:12 PM   #5
FRS Justin
That trunk monkey is pissing me off lol
710whp
The Following 3 Users Say Thank You to FRS Justin For This Useful Post:
humfrz (02-28-2020), soundman98 (02-29-2020), spike021 (03-01-2020)
Old 02-28-2020, 03:04 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
LOL!! I had forgotten about the "trunk monkey"..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Old 02-28-2020, 06:20 PM   #7
norcalpb
norcalpb's Avatar
Take apart the dome light. You’ll see the back of the dome light knob has a metal strip on it which corresponds to the 3 thin metal “fingers” that power the 3 dome light settings. I think over time these metal fingers get bent with use of the knob, so bend them back into place so they have a tight contact with the metal strip on the knob.
Old 02-28-2020, 09:04 PM   #8
FRS Justin
This is a different issue as its being controlled. If you hook up techstream you can see the light being activated.
710whp
Engine oil light briefly flashes after start up shu5892001 Issues | Warranty | Recalls / TSB 6 09-24-2014 01:52 PM
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 10:39 PM
Door does not trigger dome light modena Issues | Warranty | Recalls / TSB 24 03-17-2014 07:27 PM
FS: Cool White LED Lighting (dome, door, and trunk lights) fourvalleys Interior Parts (Incl. Lighting) 0 11-18-2013 07:55 PM
Interior Dome Light in DOOR mode works in reverse! shaoster Cosmetic Modification (Interior/Exterior/Lighting) 1 04-07-2013 02:37 AM
