Drives: Crystal white brz
Check engine codes P0171, P1170, C1201, C1231, and c1241 HELP
Anyone had all these thrown at the same time?
Backstory: I have a full blown kit with injectors, exedy clutch, DW 300c fuel pump... today while driving in my neighborhood at maybe 12mph I looked down and noticed the CEL and traction light were on. I turned around and went back home. Car runs fine, seemingly. I pulled the codes via EcuTek... does anyone else have any ideas? I purchased some plugs today as they are overdue. Tomorrow I plan to make sure everything is connected well, and kind of go through the car.. Thanks in advance any and all with advice! |
#2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
System lean, port injector performance, ABS/VSC disabled by PCM. Engine wants more fuel, topping out fuel trims but fueling is normal under direct injection. Anything about your mods spring to mind? Diagnosing a car over the internet is already hard, diagnosing a modded one is extraordinarily so, but with the detection logic on those codes, first thing I'd check is fuel pressure on the PFI side.
The last two codes are steering angle sensor related, I'd wager they're not active codes since they're the kind of codes that are seen with low system voltage during or after a car has been left KOEO and drained the battery too far. |
#3 | |
humfrz |
#4 |
[insert cool phrase here]
Drives: BRZ Premium
No sure @humfrz
When my tracktion control and CEL came on my code was a P1441 if I recal. It only happened after slipped the rear tires a bit during a light rain. I cleared the code and it didn't came back. Hopefully it's nothing just a bug but let us know what code it is. Since you have more mods on it, it might be more difficult to pin point it.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | humfrz (05-11-2019) |
#5 |
@RZNT4R I really appreciate the response. I haven’t had a chance to look over anything yet. Nothing comes to mind as far as mods. Been running strong for a year now with no issues. How would one go about checking fuel pressure? I will search it as well. Thanks again.
#6 | |
![]() humfrz |
#7 |
@hmfrz and @Mr.ac thanks for responding! I cleared the codes on EcuTek and then started the car.... they were off. I haven’t driven it or done any logs yet. Maybe it was a fluke?
#8 | |
Drives: BRZ Premium
It could have been some random thing the traction control didn't like. Mine didn't come back after I cleared it.
#9 | |
![]() humfrz |
#10 |
I will update on what I find tomorrow if anything..
#11 |
As an update, I think this was just a bad exhaust leak? The down pipe from the turbo had very loose bolts that I re-torqued and applied thread locker to. After clearing the codes I haven’t had anymore issues.
| Lean engine codes p0171 | zackegle | Issues | Warranty | Recalls / TSB | 23 | 03-14-2022 01:17 PM |
| Odd idle and P0171 and P1170 codes | dave- | Engine, Exhaust, Transmission | 0 | 09-27-2018 12:05 AM |
| Throwing P0171 and P1170 codes | B-R-Z | Software Tuning | 39 | 01-27-2018 10:56 PM |
| Need help. Video and codes P2271, P0171, C1201, U0100 | voidn0ise | Issues | Warranty | Recalls / TSB | 8 | 05-03-2017 06:58 PM |
| too lean issue? p117B p0171 engine codes | zackegle | Issues | Warranty | Recalls / TSB | 1 | 03-21-2017 09:03 PM |
