Old 08-01-2018, 10:13 PM   #1
Brink
Drives: 2017 BRZ
2017 HU with streaming music from phone
When I use a music streaming app like Pandora or Spotify on my phone to play over the bluetooth connection to the HU it doesn't update track info properly as new songs come on. The HU will just keep displaying the info of whatever was playing when it first connected (or sometimes it doesn't display any info) until it's turned off. I never had this problem when playing music from iTunes though, it always updated properly with that. Anyone else experiencing this or know a fix? I have an iPhone 6S if that makes a difference.
Brink is offline   Reply With Quote
Old 08-01-2018, 11:01 PM   #2
Grady
Grady's Avatar
Yep the head unit sucks! Same on mine.
Old 08-01-2018, 11:10 PM   #3
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Apple Music works. Most other stuff doesn’t. Just get a nice exhaust and listen to that instead...LOL
TofuJoe is offline   Reply With Quote
The Following 2 Users Say Thank You to TofuJoe For This Useful Post:
MidEastBeast (08-03-2018), spike021 (08-02-2018)
Old 08-01-2018, 11:11 PM   #4
Brink
Drives: 2017 BRZ
Sometimes I do just listen to the exhaust, but when I want to listen to music I like to know what I'm listening to.
Old 08-02-2018, 12:59 AM   #5
Chris_
Drives: 17 BRZ PP
Same on mine. I brought it in to see if there were any firmware updates but was told there weren't any.
Chris_ is offline   Reply With Quote
Old 08-02-2018, 10:23 AM   #6
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
This problem isn't just specific to our cars. My friend has a 2016 Impreza with a starlink radio and it does the same thing when streaming Spotify.
tehShirt is offline   Reply With Quote
Old 08-02-2018, 10:42 AM   #7
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Are you referring to the Pandora "app" or just the bluetooth connection? My phone almost never connects to the actual Pandora app. But when it's streaming just through the bluetooth connection, I just ignore whatever the screen says so long as I can listen to my music.
MS, CSCS, TSAC-F, CPT
Old 08-02-2018, 01:40 PM   #8
Brink
Drives: 2017 BRZ
The lock screen on my phone displays the correct info, it's just the HU that doesn't update. Although I think I found once that it only works if Pandora was the last thing playing on my phone when it connects so it starts playing automatically - if I try to open Pandora and start it manually after it's connected to the HU it does some dumb Starlink thing.
Old 08-02-2018, 02:44 PM   #9
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Yup, the factory head unit sucks in both function and sound. There is an auto-launch on BT setting in Pandora (on Android, I’m not sure about the iPhone) that seemed to help some with Pandora connecting and displaying track info accurately. Ultimately, the best solution is to upgrade to an aftermarket head-unit, which is what I did just a few months after buying my BRZ. The aftermarket head unit (Pioneer AVH-2330NEX in my case) is better in every possible way than the factory unit.
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
TofuJoe (08-02-2018)
Old 08-02-2018, 11:31 PM   #10
TofuJoe
Ohne Titel
TofuJoe's Avatar
Does the AVH-2330NEX work with the stock faceplate?
Old 08-03-2018, 12:02 AM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yep same issue has you but I use the USB cable, for me that update the info after each song. Via Bluetooth it's hit or miss.
Old 08-03-2018, 01:01 AM   #12
MidEastBeast
Drives: 2017 Subaru BRZ Series. Yellow
No. Do research on it first. The 2017 HU has the trapezoidal configuration. You'll need to buy a harness or something to cover the inevitable gaps.
This is one example: https://www.ebay.com/itm/Connects2-C...item58fc6bc56e
MidEastBeast is offline   Reply With Quote
The Following User Says Thank You to MidEastBeast For This Useful Post:
TofuJoe (08-03-2018)
Old 08-03-2018, 08:30 PM   #13
NCtoBRZ
I used the Scosche dash kit https://www.crutchfield.com/p_142SU2...t.html?tp=3121. Just about any standard single or double din aftermarket head unit will fit with this dash kit. Obviously you’ll also need a wiring harness and several adapters depending on which functions that you care to retain such as steering wheel controls, factory USB & aux, satellite radio.
Old 08-16-2018, 08:23 PM   #14
Rederick
Drives: 2017 BRZ PP, 88 Yota 4x4 SC'd
god damn this head unit sucks. I have a 2017, and thought I was going crazy trying to get pandora/bluetooth audio to work more than 1% of the time. I for the life of me can not figure out what magical process is required to get pandora to link up via bluetooth. I just works randomly once then never again for a few weeks.
Rederick is offline   Reply With Quote
2017 BRZ - Transferring single phone contact FlipperBizkut BRZ First-Gen (2012+) — General Topics 4 12-11-2016 06:59 PM
2014 OEM HEADUNIT USB MUSIC ISSUES (Cant browse music folders) VuDism Electronics | Audio | NAV | Infotainment 12 05-29-2014 06:47 PM
Stream music from smart phone to car via bluetooth itisthumper Electronics | Audio | NAV | Infotainment 6 12-05-2012 01:59 AM
Sound quality of Bluetooth streaming music robo_robb Electronics | Audio | NAV | Infotainment 20 06-09-2012 12:37 AM
Aha Radio Streaming to BRZ borge12 BRZ First-Gen (2012+) — General Topics 25 01-18-2012 10:47 AM
