| Software Tuning Discuss all software tuning topics. |
Drives: Brz
Knock on throttle let off
Hi all, long time reader, few times poster here.
I've search quite a bit but found almost no thread about knock on letting gas off. A lot on tip-in knock, but few on the other way. I see IAM getting adjusted down because of knock (FLKC) reoccuring. However, from what I can see, it's mostly when I let off the throttle. I see some minor knock on hard pulls, but IAM is never adjusted down soon after. It also appears when I give less throttle. Let say from 10% to 50% and back to 10%. And mostly at low to moderate RPM (2500 - 4000). Mods are a Gruppe-S UEL catless header, mishimoto intake tube, Perrin panel filter, invidia q300 and an OFT. I've seen the phenomenon on V2.76 tunes, V2 OFH optimized, and V4. Here are 3 datalog I think represent the issue. The IAM is'nt changed on those exemples, but the phenomenon is represented. Any input will be appreciated! https://datazap.me/u/robzz/10-v2-26?...zoom=8320-8402 https://datazap.me/u/robzz/09-v2-25?...zoom=3605-3870 |
#2 |
Drives: FT86
make sure you don't have ant exhaust components like over pipe hitting on chassis as this can cause false knock indications.
your ltft seem quite high at +10 % check for exhaust leaks do you have stock intake ?? |
#3 |
Drives: Brz
Thanks for the reply!
I'll have a look for bruises on over-pipe. From memory, it did'nt looked near anything but I'll check anyways. For LTFT, I know they are high, particularly at idle. I "MAF scaled" it when it was a little cold outside (50°F) and those last log were taken near 75-80°F. Spring finally arrived! I have a sorta stock intake. I have a Mishimoto Intake Tube with a Perrin panel filter. I'm pretty sure I have no leaks on the tube. |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 01:20 PM |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 11:09 PM |
| Tip in knock? | bmsi30 | Issues | Warranty | Recalls / TSB | 17 | 08-25-2014 05:12 PM |
| AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 01:44 PM |
