Old 04-22-2018, 09:01 PM   #1
Pro60modman
Drives: Too many
Retuning BRZ with HKS tune, OFT and OS wont read or write
Having an issue with my HKS blown ‘13 BRZ. I can’t read or write tunes with OFT or OS. It fails when it tries to unlock the ECU. Is this due to the HKS Flash Editor tune currently on the car? If so will the dealer be able to overwrite a stock file to it?
Pro60modman is offline   Reply With Quote
Old 04-23-2018, 07:15 AM   #2
steve99
Drives: FT86
I have not seen a hks flash editor or tried to read\write an ecu used by hks editor
If tactrix or oft wont read it then its likely the kjs system changes the seed key access routine in ecu ie its locked. It likely if you wtire a stock rom bach to ecu with hks editor it will unlock scu again.
If you dont have the original hks editor box, then cheapest option is likely to replade ecu then write correct rom to new ecu with tactrix if you have access to one.
Ecu replacement proceedure below
http://www.ft86club.com/forums/showthread.php?t=102810
OFT Failed to Write - Tune File Erased Danklvr Software Tuning 5 09-08-2017 08:26 AM
1JZ Swap write-up AlaaTarawneh Engine Swaps 12 07-14-2016 08:00 AM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 01:43 PM
My baby is a write off T_T Wilso Scion FR-S / Toyota 86 GT86 General Forum 36 02-13-2014 09:26 PM
