Old 03-14-2018, 04:46 PM   #1
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '17 BRZ, '24 CX-50
Motul Gear Competition 75W-140 in Transmission and Diff
EDIT: Mods I realized I posted this in the wrong forum, I have now posted it in the maintenance sub forum. Feel free to delete if desired.
Hey guys,
About a month and a half ago I went to a local performance shop to swap out the factory fill of trans and diff fluid for something a bit better (at about 18k kms).
I know that many in the community use Motul Gear 300, so when my mechanic recommended Gear Competition I really didn't think twice about it. He said its his go to recommendation for Subaru's (WRX's, STI's BRZ's and FRSes) and has used it many times in the past so I trusted his word.
Now upon doing more research about it, I am getting worried that I may be doing harm to my trans/diff. Should I flush and fill with a 75W-90?
JBezugs is offline   Reply With Quote
Old 03-14-2018, 08:29 PM   #2
CSG Mike
CSG Mike's Avatar
Fine in both, but you may find reduced mpg and increased notchiness shifting.
Old 03-14-2018, 08:36 PM   #3
Teseo
Drives: frs
On cold temps right? Because on warm or driven for a while shifting improve dramatically
Old 03-14-2018, 10:46 PM   #4
CSG Mike
CSG Mike's Avatar
Ultimately it's not what's recommended by the manufacturer. I don't believe it will hurt the car *short term*
Your car, your risk.
Old 03-15-2018, 10:30 AM   #5
JBezugs
Good Job Subaru!
JBezugs's Avatar
Noted. I may keep this fill then until my next interval and switch to Gear 300 after that. I haven’t noticed anything out of the ordinary; it is notchier than the stock fluid in the cold (below 5 deg C) when nothing has warmed up, but I double clutch on upshifts and downshifts when the car is cold anyways.
Otherwise the shifter feels better than the stock fluid once up to temp.
As an aside, I know second gear can be “crunchy” in this car from time to time, but I also get the odd bit of synchro noise when shifting to third as well (fairly rarely, maybe once on a 45 min commute). I had this issue with the stock fluid as well. Does anyone else have this issue?
Old 03-15-2018, 12:51 PM   #6
Yes, sometimes ...... if I get "lazy leg" ...... don't push the clutch pedal all the way to the floor ......
Old 03-15-2018, 04:55 PM   #7
JBezugs
Good Job Subaru!
JBezugs's Avatar
Fair enough! I may be doing the same without realizing it...
The Following User Says Thank You to JBezugs For This Useful Post:
humfrz (03-15-2018)
Motul Gear Competition 75W-140 for differential? Tor Tracking / Autocross / HPDE / Drifting 13 09-11-2016 09:01 PM
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 10:24 AM
Limited Slip diff oil Motul GEAR 300 LS 75W-90 FRSToyota86 Canada Classifieds 12 08-22-2014 01:47 PM
Trans/diff fluid recommendations: Motul Gear 300, Extra-S, or.. B-R-Z Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 07-03-2014 09:06 PM
Transmission fluid blending Redline MTL and Motul Gear 300 okay? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-01-2013 09:03 PM
