Old 01-03-2017, 07:14 AM   #1
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
2017 BRZ - has anyone managed to retain the OEM mic?
2017 BRZ - has anyone managed to retain the OEM mic with an aftermarket head unit?
softgrip is offline   Reply With Quote
Old 01-05-2017, 05:01 PM   #2
mikemassoom
Drives: 2014 Scion FRS (Monogram)
I want to know this as well. Thinking of installing a DNX693S and wasn't sure how this would work.
mikemassoom is offline   Reply With Quote
Old 01-05-2017, 07:38 PM   #3
softgrip
I know you can't do it with 2016 - as mine had a weird Bluetooth phone adapter mic thing
Old 01-06-2017, 09:10 AM   #4
Chimera
Drives: FRS
My understanding is that the oem is a stereo mic and not very good. That said, if you have your heart set on it, go get a 3.5 aux cable, cut it in half, splice out the leads and tap into the oem mics leads. Youll need a 3.5 to 2.5 adapter to fit most after market head units.
Old 01-06-2017, 09:40 AM   #5
jasonojordan
Drives: 2013 satin white brz limited
I've thought about retaining it in the 2013 and it looked to be more hassle then its worth so plan to just use the one that comes with the car and route the wiring and find a decent spot to mount it.
jasonojordan is offline   Reply With Quote
Old 01-07-2017, 11:06 PM   #6
Eman
Drives: 2013 Scion FR-S 10 series
I was told it could not be done so I mounted my aftermarket mic in the stock location. I ran the wire up the pillar in the normal fashion then along the headliner. When I got to the center I fished it through to the stock mic location (after removing the stock mic of course). Then I used some 3m double sided tape to mount it inside the oem Housing, pointed towards the driver side. It looks completely stock, you would never know.
Eman is offline   Reply With Quote
The Following 3 Users Say Thank You to Eman For This Useful Post:
azonic (04-22-2018), JohnJuan (04-25-2018), TofuJoe (04-23-2018)
Old 08-26-2017, 02:08 AM   #7
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
The OEM mic is not stereo. It's definitely mono. However, it is inside a module with a small amplifier circuit, which requires 5V power. The signal coming out of that is too loud to use directly with an aftermarket head unit.
Theoretically, you could design a circuit that supplies power to the OEM mic and reduces the level back down to what an aftermarket HU wants, but I haven't heard from anyone yet who has done that successfully. It's not worth the effort, IMHO. Just do like Eman said.
SVXdc is offline   Reply With Quote
The Following User Says Thank You to SVXdc For This Useful Post:
TofuJoe (08-26-2017)
Old 08-26-2017, 12:45 PM   #8
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
I managed to get it working with a really hacked-up version of what SVXdc just said, but it worked like poop. Not to mention modifying the stock harness behind the radio for the mic was more extensive than it's worth.
I completely understand the allure of using the factory mic on a new head unit, but take it from me, it's not worth it in the end when they give you one with the head unit that works great as it is. Just pop the factory mic out of the stock location and run the aftermarket one in there.
sharpsicle is offline   Reply With Quote
Old 01-26-2018, 05:52 PM   #9
Shanahan
Shanahan's Avatar
Older thread, s but I want to revive it. I want the oem mic and cable if someone is removing theirs. I want to put a Toyota oem Head unit in my 93 Mr2. I want to be able to use the oem mic since it is amplified and designed to work with this unit. Trying to go modern while staying oem. Matches the “modern” motor also swapped in my classic car.
Shanahan is offline   Reply With Quote
The Following User Says Thank You to Shanahan For This Useful Post:
Chimera (01-27-2018)
Old 04-22-2018, 12:52 AM   #10
Shanahan
Shanahan's Avatar
Can you elaborate on how you did this?
I am mostly interested in the pin outs and wires to the oem mic. The mic has 3 wires; red, black and white. What pins does that correspond to at the headunit end. I assume they are pins in the 28 pin plug.
Old 04-22-2018, 05:23 AM   #11
gpvecchi
gpvecchi's Avatar
Following
Old 04-22-2018, 03:18 PM   #12
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
See this thread http://www.ft86club.com/forums/showt...=100354&page=6starting with post #79... it doesn’t seem worth the effort when the aftermarket mic will work just fine and you can hide it so that nobody is the wiser.
NCtoBRZ is offline   Reply With Quote
Old 04-22-2018, 04:15 PM   #13
Shanahan
Shanahan's Avatar
Thanks I’ll check it out.
I am not trying to keep it in an frs. I am doing a retrofit of all oem parts into my resto mod restore on a 93 Mr2 turbo with a gan4 3sgte swap aka modern motor in a classic car.
Old 04-30-2018, 12:31 PM   #14
RobAus
Drives: 2013 BRZ Limited
The stock microphone is useless while moving due to loud cabin noise. A noise canceling microphone would be better but I don't know what is available. I use a wireless bluetooth noise canceling headset paired to the phone.
RobAus is offline   Reply With Quote
I finally managed CelicaJoe BRZ First-Gen (2012+) — General Topics 23 06-12-2016 04:10 PM
retain factory aux port rsingh Electronics | Audio | NAV | Infotainment 2 10-23-2015 08:09 PM
Which EL headers retain engine tray? 86_PWR Engine, Exhaust, Transmission 8 07-30-2015 11:06 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 03:09 AM
DIY - Auto up/down disable (and retain door open indicator) Imperius DIY (Do-It-Yourself) Guides 4 02-10-2014 04:17 AM
