| DIY (Do-It-Yourself) Guides For all DIYs. |
So I was thinking, what are all the parts that we can swap out with other cars for our parts and vise versa? Example: Brembo brakes from certain year STi can be used on our cars. Etc. Anyone?
#2 |
Drives: Scion frs
I know the atsv and 300zx brakes fit with a bracket. Anybody have any others?
Sent from my SM-G930W8 using Tapatalk |
#3 |
Rear control arms, rear sway bar and rear top hats from the '11-14' STI fit.
#4 |
Drives: 10 Series #974 6m/t
M85 rear differential from an IS300 (1st Gen)
#5 |
Drives: 2013 Supercharged BRZ, E85, Ohlins
GT3 brake duct 'flaps'
forester oil cooler WRX 4-pot and 2-pot F/R subaru calipers, requires brackets |
#6 |
Drives: 2014 WRB BRZ Limited
-2005 Toyota Matrix air filter
-Any non-STI/+2015 WRX Subaru wheels + most VW wheels -Same manual transmission as last-gen Miata and Genesis Coupe (not sure if manual for the 2.0T was same as 3.6?) -Same automatic as Lexus IS-F
#7 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Wrong. It's closer to the IS250 actually (dont recall if its 100% the same or not). The isf rumor was nothing but that, a rumor.
| The Following 3 Users Say Thank You to finch1750 For This Useful Post: |
#8 |
Same tires as a Prius.
#9 |
Is not fast.
Drives: 2014 Whiteout M/T
I think you can swap the M/T shift knob from a 2016 BRZ to a 2013 FR-S... but don't quote me on that.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
#10 |
S🅱️inalla
Drives: 2013 Subaru BRZ [WRB]
16mm rear sway bar from 2008-2014 WRX. Stock BRZ/86 is 14mm.
#11 |
Senior gif poster
Drives: 2013 Asphalt FRS
If you do the proper alterations you can fit Ford Raptor wheels or other similarly sized large truck wheels.
| Big power fa20 parts/trans swap | spitfire481 | Engine, Exhaust, Bolt-Ons | 18 | 11-26-2016 09:59 PM |
| 4.56 FD Swap Parts and Labor :) | Aztec | Engine, Exhaust, Transmission | 31 | 02-09-2016 04:27 PM |
| 2jz swap parts | Uhoh_Oreo | Transmission and Driveline | 2 | 07-07-2015 06:55 PM |
| 2jz swap parts | Uhoh_Oreo | Engine, Exhaust, Bolt-Ons | 10 | 03-13-2015 08:26 AM |
| NY:BRZ & FRS PARTS SWAP THREAD! | SalM | NY / NJ / CT / PA | 16 | 07-08-2014 11:07 AM |
