Old 07-11-2012, 10:45 AM   #1
oops86
oops86's Avatar
Drives: Scion FR-S
Oil change after break in?
I just hit 1004 miles on my FRS the other day. I visited by my trusted mechanic to pick his brains a bit about what oil to use. He said since I'm not going to be pushing the car too hard and just use it as a country road driver, sticking with the 0w20 oil will probably be just fine. I asked him if he thinks I should swap out the oil on the car now that I'm through with the break in period and he said "Nah. Just wait until you hit 3k and come in for a change."
I'm a bit worried about particle deposits from the break in period though, so I'm tempted to get it swapped early. Will I harm the engine if I go one route or the other?
oops86 is offline   Reply With Quote
Old 07-11-2012, 11:05 AM   #2
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
The only thing you can hurt by changing your oil too frequently is your wallet (Provided you don't cross thread anything or otherwise damage something in the process of changing the oil course). If you're concerned about it, then change the oil. No harm will come from it.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 07-11-2012, 08:39 PM   #3
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
+1. Its worth it if it gives you a peace of mind.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
The Following User Says Thank You to ft86Fan For This Useful Post:
Acc (07-26-2012)
Old 07-26-2012, 08:05 PM   #4
Acc
Old Schooler
Drives: GD, GC, NPS50
For new cars i change at 1K then at 2K then normal 3K oil changes at the time.....Then go synthetic around 15K....just the way I have always done it so thats what i stick with.
Acc is offline   Reply With Quote
Old 07-31-2012, 12:59 AM   #5
jurjurson
Drives: 2013 c63 & 2012 370z Sport/Navi
change ur oil everyday!
jurjurson is offline   Reply With Quote
The Following User Says Thank You to jurjurson For This Useful Post:
SkAsphalt (08-01-2012)
Old 07-31-2012, 10:19 AM   #6
JohnATL
JohnATL's Avatar
Drives: 2013 Scion FR-S MT Raven
I plan on doing a 1K, 3K and then every 5K. I'll probably stay with the 0W-20 with Ran Up.
JohnATL is offline   Reply With Quote
Old 07-31-2012, 03:09 PM   #7
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
I just did mine.. I'm a few miles shy of 1000. I like the idea of getting the initial metal deposits and stuff out as I'm finishing break-in period.. this way I can feel more comfortable revving the engine higher moving forward.. Not saying I'm planning to to redline often.. but I'll at least feel comfortable over 4k rpms when I need or desire.
I think 1k miles is great.. then I'll probably do it again at 5k, 10k, 15k, etc..
eikond is offline   Reply With Quote
The Following User Says Thank You to eikond For This Useful Post:
korhun (06-24-2019)
Old 07-31-2012, 04:26 PM   #8
jarviz
jarviz's Avatar
Drives: Raven FRS MT
How much is everybody paying for an oil change? I paid 12 bucks for labor and about 45bucks for 0-20w oil. I can see this getting a little more expensive than my usual oil change for a coroalla.
jarviz is offline   Reply With Quote
Old 07-31-2012, 04:36 PM   #9
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Just spent $100 on 12 quarts of Royal Purple, and 7 on a K&N Filter. Doing it myself that's only $53 bucks. Hopefully with better oil than most places provide.
I did spend $23 on a drain valve, but that doesn't count per change in my mind.
Going to change it today if that valve comes in. Just over 1400 miles.
michaelahess is offline   Reply With Quote
Old 07-31-2012, 04:40 PM   #10
_hollywood
Drives: 97 itr sold
Am i the only one waiting till 7500 like the manual suggests?
I just want to go by the book until the warranty expires
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 07-31-2012, 04:41 PM   #11
lordtakuban
You should return the Royal Purple ASAP and buy some Redline Full synthetic oil. It's Ester based and not crappy oil with good marketing hype like Royal Purple. If you really want to go baller, get some Motul 300V. If you want more budget minded oil that is still really good, get Amsoil. Basically, just about anything is going to be better than Royal Purple. Good luck.
Old 07-31-2012, 04:44 PM   #12
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
I am changing mine this week, planned on doing it right after break-in, but i've been so busy lately. I'm at 1400 mi.
itsibarra is offline   Reply With Quote
Old 07-31-2012, 04:54 PM   #13
eikond
eikond's Avatar
$7 for the a filter from Subaru (I've heard Scion dealers are charging $20 for the same part )
I decided to try Mobil 1 0W-20 this time. 6 quarts from Wal-Mart was around $38. I used a hair less than 5.5 so next time I'll only need 5 quarts... assuming no oil consumption issues
So figure around $45 per oil change. If I'm not happy with the Mobil 1 then maybe I'll try something different.. we'll see.
No reason to pay for labor... super easy oil to do in your driveway in 15 minutes.
Old 07-31-2012, 05:04 PM   #14
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
0-20 is all fully synthetic, so you have to use it right away on this car.
I personally changed mine at 1500 miles for piece of mind.
blu_ is offline   Reply With Quote
FRS Break-in guide denkigrve Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 182 12-09-2019 12:13 AM
Best Break-in Procedure xantonin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 198 02-11-2015 05:40 PM
End of break-in! Now where do we go play? MTL QC-FRS CANADA 3 06-29-2012 11:05 PM
Break-in question Baldeagle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-31-2012 03:28 PM
Break-In Period UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2012 04:26 AM
