Old 10-30-2017, 04:57 PM   #1
veuxx
Drives: 17' 86
Looking to buy!
Looking to purchase a older FRS - have there been any issues to look out for on this boxer engine/transmission?
and can anyone point me to where I can buy a painted OEM wing for the FRS - do the BRZ/86 will they fit?
Thanks!
veuxx is offline   Reply With Quote
Old 10-30-2017, 05:11 PM   #2
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Forums, because typing in the question you're asking on Google would have been too difficult.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 10-30-2017, 05:18 PM   #3
veuxx
Drives: 17' 86
None of those were from Toyota but seemed to be offbrand to look like the OEM style but not OEM.
I googled for 20 minutes and wasn't really sure as I don't know much about the FRS.
I saw you could buy the Toyota 86 wing unpainted from Toyota now.
Will this fit on the FRS as it never came with a wing - unless I'm wrong.
Is there someplace I can purchase it painted or do I need to take it to a shop?
Thanks!
Old 10-30-2017, 07:22 PM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
https://parts.toyota.com/accessories...r-Styling.html
I've had my entire transmission swapped out under warranty for 5th gear grinding
CEL for ignition coils
The Following User Says Thank You to Bonburner For This Useful Post:
veuxx (10-30-2017)
Old 10-30-2017, 07:50 PM   #5
Thanks!
Oh, generally the older FR-S/BRZ cars have held up well.
Most of the problems have been caused by people messen with them ...... namely, forced induction, or tracking the hell out of them.
If you can find one that hasn't been unmercifully tracked or force fed and it shifts OK ........ it should be a good one.
stevesnj (10-31-2017), veuxx (10-30-2017)
Old 10-30-2017, 09:44 PM   #6
Noodle86
Drives: 2015 RS1
Thanks!
So the spoilers should fit brz to frs, frs to brz.the 2017 wing. They added extra bracing to the trunk to support it. Atleast that's what I'm reading from other people. So other peeps that have better knowledge, if I am wrong please correct me. Good luck to you buy, i just purchased mine a couple of weeks ago and enjoy it very much!
Noodle86 is offline   Reply With Quote
Old 10-30-2017, 09:51 PM   #7
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
"have there been any issues to look out for on this boxer engine/transmission?"
No real problems there, it's with the overall package..the car.
These things are extremely addictive...similar to the current Opiate problem in the USA.
If you purchase, may require later, detox and rehab.
ToySub1946 is offline   Reply With Quote
Old 10-30-2017, 10:49 PM   #8
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
test drive a brand new one and make sure you test drive any used one as you should be able to discern most issues that way. if ya wanna completely avoid the teething issues (and get a few creature comforts like padded knee rest) go for 14+
HKz is offline   Reply With Quote
Old 10-30-2017, 10:58 PM   #9
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
Get the car's service history, see if the throw out bearing has been changed as that's one of the few common issues I see. It's a cheap part but labor can get expensive if you're over the warranty mileage (gonna have to deal with mine soon). I wouldn't even consider that a MAJOR issue, but it's a common one on older models. Check for signs of mods, of course.
Other than that, you don't have to expect more than regular fluid changes, brakes, and tires.
Beachin86 is offline   Reply With Quote
Old 10-30-2017, 11:37 PM   #10
Decep
Drives: 2013 FR-S Series 10
Oil leaks is pretty much the most common thing you will run into in terms of engine problems. Makes for a smelly car as the oil burns off onto the exhaust headers when you're idling.
Old 10-31-2017, 12:20 AM   #11
Lonewolf
Lonewolf's Avatar
Drives: Moped
Thanks!
I wouldn't buy a 2013 unless it is a hell of a deal...too many first year teething problems, just like most cars
Old 10-31-2017, 02:05 AM   #12
thirty3
Drives: 2013 FRS, 2005 S2000, 07 Tacoma
I had a throwout bearing go out in my car but Toyota replaced it under warranty and didn't say anything about my supercharger
thirty3 is offline   Reply With Quote
Old 10-31-2017, 08:48 AM   #13
stevesnj
stevesnj's Avatar
https://www.toyotacertified.com/inve...R-S;radius=100
My 2016 Build thread
