Old 08-05-2014, 04:26 PM   #1
Djratrap
Drives: BRZ CSB Limited
p0016 issue
I was driving home the other day and had the p0016 CEL. My car has aprox 39k miles on it with no mods other than drop in filter. I have taken it to the dealer 3 times now as the code keeps returning. They are currently flushing my engine ($160) to remove any sludge from the oil valves and are going to continue from there(hopefully no more work). Is anyone currently experiencing/experienced a similar issue? If so, what did you do to remedy the situation. I read that one person had a similar issue, but had to lemon their car. My car is out of lemon range for my state, so i'm just trying to prepare myself for worst case scenarios. I suppose engine replacement, would be the absolute worst case.
Djratrap is offline   Reply With Quote
Old 08-05-2014, 05:10 PM   #2
stevemp5
Drives: scion fr-s
I found this thread, maybe help you!
http://www.ft86club.com/forums/showthread.php?p=1485819
stevemp5 is offline   Reply With Quote
The Following User Says Thank You to stevemp5 For This Useful Post:
Djratrap (08-05-2014)
Old 08-05-2014, 06:26 PM   #3
Djratrap
Thanks, i saw that thread. Unfortunately it was a dead end thread with no documented resolution. I have had my ecu reflashed by the dealer with no improvement of the CEL. Waiting game i suppose.
Old 08-05-2014, 06:33 PM   #4
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
What was found for my car with a bunch of codes was that the oil control valve had metal shavings inside of it. Ask them to pop them open to check. They're right on the front of the engine and have like... 3 or 4 tabs holding them together.
Or ask them to simply swap the control valve to another bank and see if the CEL stays on bank 1 or if it follows the valve to bank 2.
EDIT: I see you're in Seattle - Why don't you give Bob @ Drift Office a call.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
Old 08-06-2014, 12:04 AM   #5
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Keep us updated
Jmonty is offline   Reply With Quote
Old 08-06-2014, 12:19 AM   #6
sirsol66
Drives: 2013 FRS- Hot Lava
Out of curiosity, what is your build date and ecu tune? Original or reflashed?
sirsol66 is offline   Reply With Quote
Old 08-06-2014, 06:38 PM   #7
Djratrap
So the engine flush did nothing (of course), they are replacing the ECU and a cam gear. Not sure what my build date is, never checked. I'll check when i get the car back (whenever that is). Last 6 of Vin is 607471. I was running the original tune prior to the re-flash(most recent?) a few days ago (also did nothing). They are trying to get me to pay for the engine flush still ($160). I called corporate and and gave them an earful about how i am not going to pay and to call that dealership.
Old 08-07-2014, 03:12 PM   #8
Djratrap
Update*
The dealership was claiming that i didn't perform my regular interval oil change and that i have to pay for the engine flush. Regardless of the fact that I have an after-market filter which would indicate that i changed my oil in between the last dealership oil change (f@cking stupid). I was pretty livid. They also claim that the cam gear issue is because i didn't change my oil in recommended intervals. I am pretty furious right now, but at least they are replacing my cam gear and ECU under warranty. I'm never going to that dealer again for any service. I had a great purchasing experience through them, but the service department can suck my d!ck (excuse my French).
***STAY AWAY FROM SUBARU OF PUYALLUP SERVICE DEPARTMENT.***
I've had two master tech friends also question the engine flush. I'm sure you guys already know this, but keep all oil change receipts outside of the dealer changes, or they will use it against you.
Old 08-07-2014, 03:21 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Djratrap View Post
Update*
I feel your pain and frustration
I would call SOA and tell them exactly what happened.
what if i don't have all receipt, my car is going to bomb!? pheww
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Djratrap (08-07-2014)
Old 08-07-2014, 03:27 PM   #10
Djratrap
I called SOA, they basically told me i'm SOL. KEEP YOUR RECEIPTS and staple them to the service record book.
Old 08-07-2014, 07:50 PM   #11
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Make that 3 Master techs that think the flush was BS.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following 3 Users Say Thank You to AZFA20 For This Useful Post:
Djratrap (08-07-2014), Guff (11-02-2014), Sportsguy83 (06-06-2017)
Old 08-13-2014, 11:05 AM   #12
Djratrap
*Update*
So i got my car back and everything seems to be okay. They replaced 2 cam gears with pretty decent turn around. The service department also redeemed itself and decided not to charge me for the engine flush.
Old 09-04-2014, 03:59 AM   #13
Djratrap
Update #2, so the cell came back on for a P000B code (after putting rougly 2k on the new cam gears). I'm not sure what to do? My car is out of lemon law, mileage too high. I'm calling corporate in the morning. I took the car back to Subaru Puyallup today and they said it was a "not tightened gas cap." They code came back on about and hour after leaving the dealership. When i got home i ran the obd2 reader on it and pulled that code. Def not a gas cap.
Pretty much done with this BRZ at this point, don't think i can get into another one, i will keep you guys posted.
Old 04-02-2015, 02:14 PM   #14
brz408
Manny
brz408's Avatar
Drives: 13 WRB Brz
Any updates on this?
brz408 is offline   Reply With Quote
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 06:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-17-2021 12:09 AM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 04:49 PM
LED DRL issue CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 4 08-12-2013 06:15 PM
Anyone having this issue? zoomzoomers BRZ First-Gen (2012+) — General Topics 11 08-10-2012 12:19 AM
