Dusty Raven
Drives: FR-S MT
P2419 CEL code - what to do?
Hi everyone,
I have a first year FRS with about 90k miles on it. A short while ago, I had the CEL come on (along with the traction control light) when I hit a bumpy part of road. Torque found one code - P2419 - Powertrain. Evaporative Emission System Switching Valve Control Circuit Low. I reset it, it stayed off for a few weeks, but came on again (I drive dirt roads and some of the paved ones are terrible, and this seems to happen more when I am on bumpy surfaces, but I might be making that up). Anyway, I reset but now it is coming back on every 2-3 days. So maybe there really is a problem... ![]() Car seems to drive fine, don't notice any difference. The traction control light comes on and off as I drive around, CEL stays on. Any ideas? I'm hoping it's just a loose wiring harness somewhere, but I don't know where to look - don't know where the EVAP system pump/sensor/valves are located. I'm out of warranty so I'd like to take a crack at it myself if reasonably possible. Thanks! |
#2 |
You may find this reference helpful:
https://demos.starbase7.net/t3Portal..._rm_index.html I hope you get it sorted out. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | CA2 (11-09-2018) |
#3 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
the VSV is under the intake manifold
| The Following User Says Thank You to 1GiantTurtle For This Useful Post: | CA2 (11-09-2018) |
#4 | |
Dusty Raven
Drives: FR-S MT
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 12:27 PM |
| DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 | Trap63 | DIY (Do-It-Yourself) Guides | 0 | 06-14-2018 05:52 AM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 09:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 11:19 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 02:27 AM |
