Old 11-16-2016, 11:13 PM   #1
jag054
Drives: 2013 10 Series FRS
Front brake rotors swapped to rear
has anyone ever bought a big brake kit for their front brakes and then just swapped the oem front brakes to the rear brakes? if so, what exactly would you need to do? swap out the calipers and the rotors, or just swap rotors? (assuming if you swap the calipers as well the brake pads and mountings will go with it). thank you
jag054 is offline   Reply With Quote
Old 11-16-2016, 11:57 PM   #2
Tokay444
You should look into how your parking brake works, and then delete this thread.
The Following 8 Users Say Thank You to Tokay444 For This Useful Post:
8RZ (11-17-2016), churchx (11-17-2016), Guff (11-17-2016), Mr.ac (11-17-2016), Tcoat (11-17-2016), tCsonfrs (11-17-2016), x808drifter (11-17-2016), yelsew (11-17-2016)
Old 11-17-2016, 12:01 AM   #3
Cole
Not a troll
Cole's Avatar
Wat
Cole is offline   Reply With Quote
Old 11-17-2016, 12:05 AM   #4
D_Thissen
D_Thissen's Avatar
One way to find out!
Old 11-17-2016, 12:57 AM   #5
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
As @Tokay444 said, this is not possible due to the rear brakes having drums incorporated into them for the parking brake. Additionally, most BBKs are made with brake bias in mind, and putting a different setup on the rear that is not paired to the fronts could potentially have poor results.
- The Ancient BRZ Sacrament
by Zaku
Old 11-17-2016, 10:58 AM   #6
8RZ (11-17-2016), finch1750 (11-17-2016), Guff (11-17-2016), strat61caster (11-17-2016), wparsons (11-17-2016), yelsew (11-17-2016)
FS: OEM FR-S/BRZ front and rear brake rotors (made in Japan) DR 86 Canada Classifieds 3 10-11-2015 04:50 PM
Stock front brake rotors JS + BRZ Want-To-Buy Requests 8 09-28-2015 03:58 PM
Removing rear brake rotors? Kuzuri Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-18-2015 10:08 PM
Password:JDM Front/Rear Performance Brake Rotors 13+ Subaru BRZ password:jdm Brakes, Suspension, Chassis 63 09-22-2014 04:32 PM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 11:58 AM
