Old 08-21-2016, 02:17 AM   #1
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
18X9.75 +20, TRD springs, 245/40R18
I know there are thousands of wheel fitment threads. I've seen a lot of pictures but just not of this exact setup. Title says it all. I have TRD springs on my 10 Series and that's it. I want a certain wheel but it's only offered in an 8.75 or 9.75 which sucks. I want to run the Maxxis 245/40R18 at the height of the TRD springs. I want the +20 because I prefer the backspacing. Would this setup completely suck or what?
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 08-21-2016, 05:31 AM   #2
psybre
psybre's Avatar
with 9.75 +20, I wouldn't look at any offset below 40. With that wheel setup, you're going to have massive poke, and unless you invest more in your suspension, you won't be able to get the excessive camber required to tuck under the fender. Plus the tires would be really stretched. I have 245 on a 9" rim and that's borderline for me, I would do at least 265 on a wheel as wide as yours. But if you're going for the stance look, and these are the wheels you want, you're going to at least need the suspension updates.
try putting some options into this calculator from the sticky listed at the top of this forum:
http://www.frsproject.com/
psybre is offline   Reply With Quote
Old 08-22-2016, 09:33 AM   #3
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
yea the XXR rims you want will poke out a lot with just springs and no camber adjustment http://www.ft86club.com/forums/showthread.php?t=39218
FS: like new sumitomo 235/40r18 speeddemon Wheels and Tires 1 04-08-2016 03:05 PM
Can I do it? 18x9.5 + 38, 1" Springs HachiEnam Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-08-2015 06:43 PM
235/35 On 18x9 +35 with -1.75" Drop Springs...Possible? ShaneLindley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-06-2015 01:45 AM
FS: used- Yoshihara Design DY-12C 18x9, Sumitomo HTR A/S P01 245/40r18 bear89103 Wheels and Tires 1 09-25-2014 08:14 PM
Cheap 225/40r18 and 245/40r18 All-Season tire? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-02-2013 03:08 PM
