Old 01-10-2015, 11:01 AM   #1
Kody
Drives: 2013 Subaru BRZ
OFT - Flashing to stock error
I'm getting ready to move from Missouri to Atlanta and am trying to flash back to stock for the trip. I'm currently running a 93 stage 1 tune and am worried that I won't find a 93 octane gas station when I fill up during the trip.
Whenever I try to flash back to the stock ecu file, I get an error saying 'oops...an error occurred while writing to the ECU. Please try again.'
I'm 100% positive that the connections are secure.
The steps I'm following are like so:
1) Car is off. I plug the OFT in.
2) It asks me to key on and confirm, so I do.
3) When I select write, it starts to communicate with ECU then gives me the error.
Anyone know how to fix this?
Kody is offline   Reply With Quote
Old 01-10-2015, 11:47 AM   #2
Malt
Drives: 2015 WRX
You sure? I'd check that one more time... maybe even some light wiggling around once its in the plug. That always seemed to fix the issues when they have come up with me.
Malt is offline   Reply With Quote
Old 01-10-2015, 12:35 PM   #3
Kody
Alright, I'll go play around with that and report back.
Old 01-10-2015, 12:50 PM   #4
steve99
Drives: FT86
Might be best to test connectivity using logging or diagnostic mode.
Once you correct the issue and connection is solid during logging/diagnostics then try writing.
Writing with an intermittent connection is not a good idea.
Assume your turning ignition fully on , not just accessory.
Old 01-10-2015, 01:04 PM   #5
Kody
Yep, the ignition is fully on.
I jiggled it around plenty, blew into both ports, still have the same issue.
When I go to diagnostics and look at the current file that the ECU has, the OFT has no issues reading it. It's only when I try to write that the problem occurs. I also noted that the problem happens no matter which file is being written, the stock ECU or another stg1 93 tune.
Old 01-10-2015, 01:07 PM   #6
steve99
Drives: FT86
Try using the realtime logging screen, does that work.
Old 01-10-2015, 01:12 PM   #7
Kody
When I accessed that, it told me to 'please update the template file', so...maybe that's the real issue here.
Old 01-10-2015, 01:31 PM   #8
steve99
Drives: FT86
ok make sure your running Open flash manager 1.15.1 plug oft into computer and let it update after its updated then also update the template file
Old 01-10-2015, 02:26 PM   #9
Malt
Drives: 2015 WRX
That could be it! If you connected it to open flash manager and it auto updated from a version that required a template update as well, it could cause that problem.
http://openflashtablet.com/Automotiv...ads/index.html
You'll have to manually download the template file from there and upload it to your tablet from within open flash manager.
Old 01-10-2015, 04:24 PM   #10
Kody
Alright, everything is completely updated to the latest version. Now the real time data display works fine, however it still can't write.
Old 01-10-2015, 08:12 PM   #11
steve99
Drives: FT86
under daignostics or ecu info will it read your rom calid. and vin number, the oft checks these two things before it will write.
have you ever edited your roms ??
Old 01-10-2015, 10:11 PM   #12
Kody
When I go to read the ECU that way everything appears to work fine, I get no errors and the information displays correctly.
No, I have never edited any rom...just loaded the stock tunes from the OFT site.
Something else curious I noticed is that when I tried to upload the stage 1 91 tune to my OFT today (after everything was updated) it said that file I selected was not compatible. However I know this to be false as I selected the 900C version, the exact same one I've used before and loaded onto my car. I have the US 6mt.
Old 01-10-2015, 11:35 PM   #13
steve99
Drives: FT86
Ok thats actually good in a way.
so diagnostics\ ecuinfo says your a 900C map and oft will not load 900C maps
it appears the oft has somehow got confused as to what your stock rom calid is so its refusing to load or flash roms to your car.
you did not somehow swap oft with someone :-)
not sure if the oft guys can remote reset it but it looksxlike you vwill have to call them and explain.
regarding your road trip the only difference between 91 and 93 tunes is ignition timing advance over 5000 rpm so if you do have to fill up with 91 just keep the rpm below 5000. till you get some 93 back in it.
the oft tunes are better than stock tune knock wise anyway.
Old 01-11-2015, 09:08 AM   #14
Kody
Awesome, that's good to know. I'll get in touch with them.
I really appreciate all your help and taking the time to trouble shoot this with me!
error sokol Cars for Sale/Trade 9 12-09-2014 03:22 AM
Flashing from openecu back to stock mhiscott Software Tuning 2 08-23-2014 09:41 PM
Flashing cel wtf ! :/ sweetfrs Issues | Warranty | Recalls / TSB 16 12-07-2013 02:13 AM
Connection Error (fr-s stock radio) Neyzo Electronics | Audio | NAV | Infotainment 5 07-18-2013 04:05 PM
anybody else see the flashing carrot??? poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 46 01-18-2012 09:25 AM
