Old 07-21-2016, 08:31 AM   #1
danielremjativa
Drives: 2013 asphalt frs
interior dome light
my dome light would work sometimes and sometimes not. then it started getting worse and now it doesnt work at all. it seemed to start happening ever since i replace the original bulb with an led but even after switching back it still doesnt work. anyone have this problem?
danielremjativa is offline   Reply With Quote
Old 07-21-2016, 08:56 AM   #2
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Haven't had that problem, but if you decide to take it to the dealership to have them look at it, make sure you have the original bulb in there.
Once I took my car for an issue and they told me I needed to avoid using LED bulbs for the interior lights because they could cause issues with some computer in the car. Idk, I've had my LED interior lights for 2+ years without any problems.
Just know that they may avoid fixing your issue under warranty if they find out you were using LED bulbs instead of the OEM bulbs.
ericmpena is offline   Reply With Quote
Old 07-21-2016, 09:24 AM   #3
KDad2
KDad2's Avatar
Drives: 2013 Raven
Check your fuses under your dash panel. If you had a bad led or the contacts crossed, it could cause one to blow. I had a blown fuse from one in my license plate.
KDad2 is offline   Reply With Quote
Old 07-21-2016, 10:28 AM   #4
Vital
Drives: 2015 BRZ
Yea if you installed a wrong size or wattage LED bulb there's a good chance your fuse is blown. Also, some of these LED bulbs cant be trusted they are just cheap bulbs coming from China
Old 07-21-2016, 10:29 AM   #5
Nickosport
Drives: 2015 WRB BRZ Premium
Hopefully the BCM wasn't shorted when you changed the bulbs. I have LEDs in my dome light and haven't had any issues. The fact that the OE bulb doesn't work tell me the problem is in the car, not the bulb. I'd definitely check the fuse before i took the car to the dealer. If you do take it to the dealer, make sure you put the OE bulbs back in.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 07-21-2016, 10:35 AM   #6
danielremjativa
ill check the fuse today. ill let you guys know what happens. thanks for the anwsers
Old 07-21-2016, 11:21 AM   #7
FX86
where did you buy the led bulb from? was it from a reputable vendor or from somewhere like ebay? did you get a DE3175 31mm festoon bulb?
i installed an aqua blue led bulb once and it would always flicker because the heatsink was defective on it...the fuse might be blown for the dome light
try to replace the fuse first as others suggested and put back the OEM bulb and see what happens
like others said if you go to the dealer install the regular bulb and act dumb saying i don't know what happened it just stopped working all of a sudden...say maybe the bulb died and it might need to be replaced? ... pretty much deny everything saying you never touched it
Old 07-21-2016, 12:54 PM   #8
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
I got my LED dome light, and a bunch of other LEDs for my car from this place -
http://www.hidpowerhouse.com
It's all good quality stuff as far as I can tell, and I have not had any issues. They are in Canada, but the prices are in USD. Anyway, it's an option if you need one. Best of luck
MY 86 BUILD
[YOYO] is offline   Reply With Quote
Old 07-21-2016, 12:56 PM   #9
FX86
Another option is VLEDS...they may be pricey but you get what you pay for these days
https://www.vleds.com/
The Following User Says Thank You to FX86 For This Useful Post:
[YOYO] (07-21-2016)
Old 07-21-2016, 12:59 PM   #10
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
Diode Dynamics or bust.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 07-21-2016, 01:07 PM   #11
[YOYO]
Amazing Member
[YOYO]'s Avatar
Yup, thats definitely a good option. They sell quality products.
MY 86 BUILD
Old 07-21-2016, 01:09 PM   #12
FX86
at the end of the day you can't go wrong with either of those guys
but avoid ijdmtoy..it's a crap shoot with them
Old 07-21-2016, 01:16 PM   #13
KDad2
KDad2's Avatar
Drives: 2013 Raven
Are there any other lights that don't work? When my license plate lights went out, so did my parking lights. I think it was a 5 amp. But, don't hold me to that. It was over a year ago.
Old 07-21-2016, 01:18 PM   #14
FX86
that's a good question...luckily i didn't have any burnt fuses on the fr-s but on a rav4 i installed a led brake light bulb and it killed the fuse so bad that all other lights stopped working and the car wouldn't even let you shift out of park without having to override the shift lock
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 10:39 PM
Interior Dome Light Issues Mongo Issues | Warranty | Recalls / TSB 3 03-19-2014 05:52 PM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 09:59 PM
Interior Dome Light in DOOR mode works in reverse! shaoster Cosmetic Modification (Interior/Exterior/Lighting) 1 04-07-2013 02:37 AM
