Drives: Toyota GT86
Draining the fuel tank
Hi there thought that I should drain out all the e85, now that the car djust sitting ther in build season.
So I thought that I could djust plug a battery direct too the fuel pump and draining it out whit the fuel line. But does anyone know witch of the four is the blue and black line for + and - on the fuel pump from the top of the casings? Djust to tiered to open up the unit to check for myself ![]() Borough that picture from someone here. |
#2 |
Drives: FT86
Even if you used pump to drain their will probably be a few litres left in tank.
Modern fuel systems are pretty well sealed so would be very difficult for air or moisture to enter system if fuel system is not pulled apart or tank cap left off. The e85 should be fine if its in a sealed enviroment, maybe add some Ethanol fuel stabilser although the only guy who had problems with his fuel filter was running additives apararantly. If it left sealed it shoul be fine for months. http://lucasoil.com/products/fuel-tr...th-stabilizers |
| The Following User Says Thank You to steve99 For This Useful Post: | NyC Zn6 (11-13-2015) |
#3 |
Someone mentioned to me to just pull a fuel line from the engine bay. Turn on the car (NOT THE ENGINE!) and let the fuel pump prime and pump all the fuel out. Not sure if it is a good idea though, maybe someone else can give input on this idea.
#4 |
Drives: '13 Ultramarine
Did you check the bottom of the tank for drain plug(s)?
| The Following User Says Thank You to roddy For This Useful Post: | celek (11-11-2015) |
#5 | |
Drives: Toyota GT86
![]() It gets too a pink/purple much because off the color adaptive that makes the E85 pink in color. |
#6 | |
Drives: Toyota GT86
![]() Only getting out a bout a deciliter at the time, and that's gone take me several hours to drain. |
#7 |
Just open the cap on both sides and siphon it out.
Sometimes, doing it the oldschool way is the easiest ![]() Or, let it idle until it stalls. |
#8 |
Drives: Toyota GT86
#9 | |
Drives: FT86
maybe might be best to run tank down / fill with petrol and flash petrol tune for winter ?? |
#10 | |
Drives: Toyota GT86
Run some good old plain 98 octane through everything. |
#11 |
Drives: Toyota GT86
#12 |
#13 |
Drives: Toyota GT86
#14 |
Drives: 2014 BRZ Limited 6MT
Wouldn't it be just as easy to run a 1/4 of 93 through it till the gas light kicked on. Should be gone by then? Or is it me being half asleep and everything seems to work simpler
| Out of fuel with 2 gallons in the tank | Simisimi | Issues | Warranty | Recalls / TSB | 31 | 06-18-2015 04:30 PM |
| Stock In-Tank Fuel Filter Degradation | sw20kosh | Engine, Exhaust, Transmission | 96 | 07-28-2014 04:36 AM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 04:39 PM |
| AEM High Flow In-Tank Fuel Pump | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 04-13-2013 01:15 PM |
| “saddle-shaped” fuel tank | ft86Fan | Engine, Exhaust, Transmission | 13 | 06-26-2012 05:22 AM |
