Drives: Subaru BRZ
Borla Muffler question
Can anyone tell me if this Borla Muffler has the right connections (i.e. input/output on one side and output on the other) for my BRZ?
https://www.partsengine.ca/borla-dua...7-p-57561.aspx thanks, 2015 BRZ Sport-Tech A/T (apologies for any wrong terminology – upgrade neophyte here!) |
#2 |
Well, as long as you have to weld a flange on the inlet side, I reckon it would come close enough.
Then, where are you going with it .......?? If you're "building" a custom muffler system, it seems to me that $400 is an expensive starting point ...... ![]() humfrz |
#3 |
Drives: Subaru BRZ
I have no idea - I'm going by the advice of a car guy I work with who would be doing the mod. I have absolutely no clue about modding.
I was going the Invidia N1 route, but he steered me toward this. |
#4 |
Drives: 2005 Toyota Camry
#5 |
Drives: frs
They are the same size. But for the money you can get better exhaust perfectly bolt on without custom work. Do you want an axleback or catback?
#6 |
Drives: Subaru BRZ
Axleback I think. Bolt on would be perfect. Any suggestions for the sound I'm after?
#7 |
Drives: Subaru BRZ
Sounds very nice!
#8 |
Drives: Subaru BRZ
That's sounds great and the price isn't bad too. Thanks for the help!
#9 |
Drives: Subaru BRZ
I got the borla but it didn't come with a gasket. Before I remove the existing exhaust, can anyone tell me if the stock gasket is a metal one I can easily reuse or if I need to go buy a new one?
#10 |
Drives: 15 BRZ LTD, 05 FXT
Grab a new one at a dealer.
#11 |
Drives: 2019 Mazda Miata RF
Borla makes two axle back bolt on mufflers, I'd just get one of those, rather than try to fab the same thing.
http://www.borla.com/products/frs_br...rt__11839.html This is the Scion option, which is euro legal: http://www.borla.com/products/brzgt8...__1014034.html |
#12 |
The problem with custom exhaust is tip alignment can be very difficult to get perfect if you are picky. Mandrel bends either require lots of cutting/welding/labor and/or an expensive mandrel bender. $400 is cheap for custom mandrel bent exhaust. Your guy is probably offering crush bent. You are better off getting a pre-fabbed exhaust that is stainless, has gaskets, flanges, hangers, and fits good. Custom at $400 probably skimps on all those things except the muffler itself.
#13 |
I believe the SP elite is has been discontinued as I tried finding where to buy it and couldn't awhile back, the clone of it is the topspeed pro 1 axleback
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | new2subaru (05-13-2016) |
#14 |
Drives: Subaru BRZ
A friend and I put the Borla axleback on tonight. It didn't take long and sounds amazing!
![]() I got it at an amazing price from ft86motorsports, way cheaper than anyone else. |
| Borla uel + dual muffler delete | Gt86_nick | Engine, Exhaust, Transmission | 16 | 06-19-2014 04:40 PM |
| What muffler to purchase for no-name setup (borla?) | jbixel | Engine, Exhaust, Transmission | 4 | 10-23-2013 02:43 AM |
| Borla header with muffler delete | WhiteFR-S | Engine, Exhaust, Transmission | 21 | 10-17-2013 02:13 PM |
| Installed Borla (plus my muffler delete) | WhiteFR-S | Engine, Exhaust, Transmission | 4 | 10-04-2013 11:32 PM |
| Muffler shop that sells/installs Borla? | Skurj | CANADA | 0 | 01-24-2013 06:29 PM |
