| NY / NJ / CT / PA NY, NJ, CT, PA |
RomRaider/ECU Flash help
Anyone have experience with ROMraider or ECUFLash that can help me get this to work? I just want to make sure i am doing this right. I dunno if its because it's a 2016 but I can't seem to get it to show the ECU info to change parameters. I live in Camden County but wouldn't mind traveling to someone not too far.
Thanks!
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#2 | |
Drives: FT86
suggest you read the Tactrix link below read out your stock rom. save the file as a .bin if its a 2016 manual its likely ZA1JF40C open it with a hex editor and search for "ZA1J" you will then find your calid |
| The Following User Says Thank You to steve99 For This Useful Post: | stevesnj (06-19-2016) |
#3 | |
My CALID is ZAJ1F00C
#4 |
Drives: FT86
#5 | |
Here's the BIN
#6 | |
Drives: FT86
OK its a ZA1JF00C rom :-) note romraider and ecuflash defs are different and not interchangeble need 32bitbase and ECUFLASH defs for ECUflash and romraider defs for romraider don't mix them up does not work. also beware of the OFT calid changes post up the rom your going to flash and ill check it |
| The Following User Says Thank You to steve99 For This Useful Post: | stevesnj (06-20-2016) |
#7 | |
#9 |
I know they are separated but I'll check.
#10 |
Drives: frs
@stevesnj if you've read the rom then EcuFlash is fine. You just need now a RR ecudef file. see this thread from RR http://www.romraider.com/forum/viewt...hilit=ZA1JF00C
You can put the file in any location, your desktop if you wish. Then open Ecu Definitions -> Ecu Definition Manager window, click Add and load the saved file, click Save. Now you should be able to open your rom. PM me if you need help, i'm maybe 20-30 mins from you |
#11 | |
| RomRaider | itsjustdavep | Software Tuning | 34 | 03-18-2017 04:48 AM |
| Tuning for CAI w/RomRaider | tskaohu | Software Tuning | 3 | 12-30-2015 08:16 PM |
| Romraider Down? | RustySocket | Software Tuning | 7 | 10-02-2015 10:28 AM |
| dbw romraider mod | RaineyStar | Software Tuning | 1 | 06-05-2015 12:53 PM |
| need some help with romraider logger | toyotaAlex | Software Tuning | 2 | 07-06-2014 08:07 PM |
