Old 07-06-2013, 12:56 AM   #1
retrosmiths
Drives: Scion FR-S Whiteout
Reduce wheel gap without lowering the car?
Total noob here when it comes to suspension, wheels and tires.
So, I don't want to lower my car (due to garage scraping issues) but I want less wheel gap. Is this achievable just by getting larger wheels or tires? If so, what sizes would be advisable?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 07-06-2013, 02:24 AM   #2
nonicname
Drives: it has 4 wheels and a motor
if you don't care about ruining car handling, response and drive ratio then you can slap some ghetto looking 19" or 20" in there but the increase in diameter will affect the way your speedometer works and the gear ratios.
This car BARELY has torque to move itself, adding huge wheels will make this car feel like you are driving a 300lbs guy in your car.
there are mild drop suspension that will fix the wheel gap enough and you won't scrape anywhere.
nonicname is offline   Reply With Quote
Old 07-06-2013, 03:08 AM   #3
retrosmiths
Example of such suspensions?
-Sent from outer space
2013 Scion FR-S
Old 07-06-2013, 04:01 AM   #4
kALMIGHTY
Drives: TRD Ultramarine '13
Either get the Tein S Techs, or wait for TRD to release their springs that'll work with stock struts and be covered under warranty if they blow. TRD isn't likely to go too low so it would probably be "just" right.
Old 07-06-2013, 04:02 AM   #5
Drftfan
Drives: Argento FR-S
Dude you live in SoCal. The Mecca of modifying imports. Just find a shop slap some springs on and call it a day.
This is your first performance car?
Drftfan is offline   Reply With Quote
The Following 3 Users Say Thank You to Drftfan For This Useful Post:
Bonburner (01-29-2014), dori. (07-06-2013), R2RO (07-07-2013)
Old 07-06-2013, 04:43 AM   #6
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
KW Suspension does a pretty decent job, but they're expensive as hell though.
EDIT: Nevermind, shouldve read the title first. Goodluck with that
LeeMaster is offline   Reply With Quote
Old 07-06-2013, 06:13 AM   #7
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
Go with an increased diameter wheel but yet again as the others have said, torque is an issue. 1" lower wouldn't hurt that much would it? go for some eibach springs and 18" wheels, you'll get more benefits than you would get with 19-20" wheels with a stock ride height.
Yamajee is offline   Reply With Quote
Old 07-06-2013, 11:12 AM   #8
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I run Eibach sportlines and 18" wheels and the gap is nice and even and I don't scrape all over either. Drop it like its hot!!
chadstyle is offline   Reply With Quote
Old 07-06-2013, 11:15 AM   #9
loogs
Drives: on cruise control
put 18's with eibach pro kit. perfect. i have a pro kit ill be selling soon real cheap. like $100.00 compared to about $250
loogs is offline   Reply With Quote
Old 07-06-2013, 11:26 AM   #10
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Just rock springs, most of the people going low are because they want to.
dori. is offline   Reply With Quote
Old 07-06-2013, 11:48 AM   #11
DGMBRZ
DGMBRZ's Avatar
Drives: 2013 Subaru BRZ in DGM
I got the Eibach pro kit. One inch drop is perfect and it's not low enough to cause any issues.
DGMBRZ is offline   Reply With Quote
Old 07-06-2013, 12:00 PM   #12
White64Goat
http://www.ft86club.com/forums/showt...highlight=Mach
Old 07-06-2013, 05:15 PM   #13
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
run wider tires with larger sidewalls.
DuMa is offline   Reply With Quote
Old 01-29-2014, 02:45 PM   #14
jadewbj
jadewbj's Avatar
Saw this, thought it may work for what you want.
Product made by GARAGE VARY to make the car look lower without having to actually make the suspension unusable. It is made to reduce the gap between the fender and tire. Price is for the full set covering front and rear fenders.
http://www.86worx.com/garage-vary-lo...der-trims.html
jadewbj is offline   Reply With Quote
The Following 2 Users Say Thank You to jadewbj For This Useful Post:
DAEMANO (02-22-2014), leicaboss (01-29-2014)
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
what's your solution to reduce the wheel well gap? chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 01-14-2013 10:25 AM
any way to reduce or eliminate "idle creep"? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 8 07-03-2012 03:00 PM
Petition to Reduce Grey Market Imports from 25 to 15 years! chulooz Other Vehicles & General Automotive Discussions 3 12-06-2011 12:59 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
