Old 07-25-2016, 05:08 AM   #1
GT86 Guy
Drives: 2016 Scion FRS Raven
How can I get my headlights perform like BMW or Lexus?
I don't like how they're yellow and not really sharp on my FRS. Is there just a certain bulb I need to insert or would I need to get a certain something from the theretrofitsource.com?
I want to get that white, clear, sharp BMW headlight look and performance or how Lexus has it.
Also the DRLs being yellow is no good as well. Anyway to fix that as well?
GT86 Guy is offline   Reply With Quote
Old 07-25-2016, 06:03 AM   #2
pauletello
pauletello's Avatar
Post
You need to get an HID Kit. I suggest something from Diode Dynamics! Look at temperatures too. I.e.:
4300k is warm white (hint of yellow)
5000k is pure white
6000k is cool white (a tiny hint of blue)
Then you can go as far as putting a Halo in the housing or whatever you would like!
pauletello is offline   Reply With Quote
The Following User Says Thank You to pauletello For This Useful Post:
FNCrazy (07-25-2016)
Old 07-25-2016, 10:15 AM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
The easiest way is to get yourself a pair of Monogram/RS/10-Series headlights with the factory HIDs. Expensive, but totally worth it.
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
kch (07-25-2016), Tcoat (07-25-2016)
Old 07-25-2016, 11:40 AM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
TheRetrofitSource Retro-Quik for Scion FRS
Use this with a 5K Bulb. You will need to bake open your headlight, or have someone install them for you if you are not comfortable enough doing it. Totally worth it though.
Old 07-25-2016, 11:55 AM   #5
FX86
if you don't want to deal with LEDs/HIDs (retrofits) then go buy the Phillips Diamond Vision bulbs for both your DRLs and low beams
It will give you a luxury white bulb look with a slight hint of exotic blue
Old 07-25-2016, 01:50 PM   #6
GT86 Guy
Anything else I would need to purchase with it? They give so many options.
Old 07-25-2016, 03:15 PM   #7
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Alternatively, the Morimoto 2Stroke kit LED has been working exceptionally for me. Same brilliant white output, not quite as powerful as HIDs but a significant improvement over stock.
To top it all off, no need to retrofit or modify the stock headlights. Haven't had anyone get mad at me for blinding them but my visibility has drastically improved.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
The Following 5 Users Say Thank You to Manic For This Useful Post:
86geek (07-26-2016), continuecrushing (07-26-2016), Josue Cafe FR-S (07-26-2016), meWant (07-26-2016), shellslinger (07-26-2016)
Old 07-25-2016, 03:18 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
A full HID retrofit would be needed for an OEM like cutoff, most likely a D2S retrofit.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Ultramaroon (07-26-2016)
Old 07-25-2016, 04:07 PM   #9
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
^ This.
Please dont be one of those assholes on the road who likes to blind everyone because their shitty headlights dont have the proper cutoff.
The Following 2 Users Say Thank You to PandaSPUR For This Useful Post:
MrDinkleman (07-26-2016), Ultramaroon (07-26-2016)
Old 07-25-2016, 04:27 PM   #10
DustinS
DustinS's Avatar
You need to select each option you want in the drop down boxes. You won't need to order anything outside of those. If you have any questions, you can call them. They have some of the best customer service available.
Last edited by DustinS; 07-26-2016 at 03:12 PM. Reason: I said Costumer, and Meant Customer.
Old 07-26-2016, 02:07 AM   #11
shellslinger
Drives: Whiteout FRS
Interesting, can you show us how's the cut off? It looks good and simple bolt on.
shellslinger is offline   Reply With Quote
Old 07-26-2016, 12:07 PM   #12
Mattstermh
Drives: '13 FR-S A/T - Stock
I am constantly blinded by guys in pickup trucks with their fuckin neon-glowing pearlescent white from the heavens lights in my rearview. I don't want to be one of those guys but definitely any improvement to the yellow bulb is nice.
Mattstermh is offline   Reply With Quote
Old 07-26-2016, 01:32 PM   #13
Manic
Is not fast.
Manic's Avatar
I'll try to take a photo tonight but I'm not sure if I can get an accurate photo of it. I've got a pretty steep driveway so I won't be able to get the appropriate 20ft to show it in my garage. At the very least you'll be able to see the pattern it makes.
I've been really meticulous about checking my pattern on other cars in front of me. It rarely goes above the bumper of a car 20 feet away and I've never seen it glint off of the side mirrors or rear view mirror. Haven't had any oncoming cars flash their high beams at me either.
The Following User Says Thank You to Manic For This Useful Post:
Old 07-26-2016, 02:21 PM   #14
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
They have some of the best costumer service available.
Great! I've been looking for size 13 stiletto heels just everywhere!
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
The Following 2 Users Say Thank You to pfaffendorn For This Useful Post:
DustinS (07-26-2016), swarb (07-27-2016)
For Those Of You Software Devs - How To Perform Better Timmy_Jones Off-Topic Lounge [WARNING: NO POLITICS] 4 11-24-2015 06:52 PM
How does the brz perform in the winter/snowy conditions Thor123 BRZ First-Gen (2012+) — General Topics 40 09-01-2015 07:27 PM
Will Toyota perform TSB's on your FR-S even though the TSB is only issued for the BRZ lupindub Issues | Warranty | Recalls / TSB 3 08-27-2015 01:05 PM
Can bags perform as well as coilovers? yuicebox Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 02-16-2014 04:09 PM
New Lexus ES leaked. Who said it's Camry of Lexus? Dark Other Vehicles & General Automotive Discussions 25 02-24-2012 02:34 AM
