| DIY (Do-It-Yourself) Guides For all DIYs. |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
Mini DIY: Zip-tie (GoPro) bar mount for large bars!
If you're using a harness bar like BK's for our cars, you will realize that the center section of the bar is too wide for any off-the-shelf bar mount to work. I ended up making a mount with little to no cost.
The key is to find appropriately sized zip ties that you can fit within the rails of the GoPro mount. I inserted one side of the top mount piece to its rail first, and then forced the other side. Align your zip ties before you fully insert the top mount, since you won't get to move it once it's in. Ready to install You probably don't need to use the adhesive bottom, but why not; it would reduce vibrations and movements at least.. Done!
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
| GoPro Mount - Ansix Auto | Ansix Auto | Interior Parts (Incl. Lighting) | 7 | 04-30-2025 01:51 AM |
| Tackform Headrest Mount for GoPro | Code Monkey | Miscellaneous | 2 | 01-06-2019 09:21 PM |
| GOPRO MOUNT | Jonathan Le | DIY (Do-It-Yourself) Guides | 1 | 06-09-2017 10:42 PM |
| DIY: GoPro tow hook mount | BatStig | DIY (Do-It-Yourself) Guides | 20 | 07-19-2015 05:54 AM |
| DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount | PMok | DIY (Do-It-Yourself) Guides | 2 | 06-11-2013 11:58 AM |
