Old 05-15-2015, 10:16 AM   #1
puma
crew chief
puma's Avatar
Drives: Race car FR-S
autoblip on ecutek
Can someone tell me how the autoblip is suppose to work on the ecutek, it seems our tuner has installed it but my friend says it doesn't work, how is it suppose to react?
Is it happenning when you are on the brake and press the clutch or what is the sequence exactly?
puma is offline   Reply With Quote
Old 05-15-2015, 10:31 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, it should work when pushing on the brake and then the clutch is depressed. Most tuners will enable it only on certain mapswitch modes and usually over a set RPM and speed so it doesn't happen at low speeds. All of that is configurable by the tuner.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-15-2015, 04:36 PM   #3
ls1ac
ls1ac's Avatar
I had it in one of my tunes and was unable to get it to work consistently. It also did not do a good job of matching revs. Learning to use your right foot will be worth the trouble.
Old 05-15-2015, 05:04 PM   #4
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
Nothing like a real heel toe vs software assist.
Touge_ninja is offline   Reply With Quote
The Following User Says Thank You to Touge_ninja For This Useful Post:
Decay107 (05-15-2015)
Old 05-15-2015, 06:12 PM   #5
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I don't understand this feature. Why drive a manual at all if using things like autoblip and flat foot shifting dull the driving experience and reduce the liklihood that one might learn or improve upon the skills required to drive proficiently?
Rev matching is not hard to learn.
Decay107 is offline   Reply With Quote
Old 05-15-2015, 06:46 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Probably wasn't set up very well. I found on track it was quite a useful feature. I bet most that put it down haven't used it. Is heel and toe more involving, sure, but I find I can't rev match nearly as easily as I could in my EK9 Type R. Maybe my skills aren't mad tight yo, but I can have it enabled in one mode and not active in another. Would I use it on the road all the time, not a chance as it's not perfect, but when driving fast or on track it's a great feature if setup well.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-18-2015, 12:49 PM   #7
ThisGuy919
It is most likely on active on higher RPMS. Mine wont blip unless im over 3k rpms which makes sense being its more of a racing application.
ThisGuy919 is offline   Reply With Quote
Old 05-18-2015, 02:21 PM   #8
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
Tell him to ask his tuner on which map the blip is.
Or, he could just rev match on his own
Sent from my toaster
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
WTB ECUtek. YEAHdams Want-To-Buy Requests 0 04-10-2015 12:54 AM
OFT vs. Ecutek JHarperFRS Software Tuning 169 05-03-2014 01:05 AM
AutoBlip intelligent Rev matching Drobinson1692 Audio/Visual, Electronics, Infotainment, NAV 8 09-22-2013 03:40 PM
ECUTek Autoblip & Launch-control features review? mit_peid Software Tuning 10 07-28-2013 06:05 PM
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 01:35 PM
