Old 02-07-2013, 02:44 AM   #1
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
lowering springs - if you did it tell me more..
not trying to debate one brand or another. my question is this. if you take the BRZ/FRS and drop it the usual 1" -- what can you expect - what did you like about it - what didn't you like - is that considered too low? do people go further than 1" ? is that typical ?
if you have any pics of your 'almost-stock' 86 lowered... that would be great too. Trying to decide if I want to do it and what to expect ..
am I going to be all paranoid about hitting the front end or is there plenty of room ?
rikdrt1 is offline   Reply With Quote
Old 02-07-2013, 08:41 AM   #2
Turn in Concepts
Turn in Concepts's Avatar
What are your goals for the car? That is where you should start in a thread like this as it will determine which springs are best for you. Do you want style, performance, track use, daily driving? All of these are important to know.
Tony
Turn in Concepts is offline   Reply With Quote
Old 02-07-2013, 09:05 AM   #3
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
1" isn't enough on this car. Go 1.4" with some Eibach Sportlines. Sits perfect and still handles great!
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
jstans84 (02-07-2013)
Old 02-07-2013, 09:12 AM   #4
BoostinIX
Gettin SIKKY sideways
BoostinIX's Avatar
Drives: '97 S14.5 / '13 BRZ
Send a message via AIM to BoostinIX Send a message via Yahoo to BoostinIX
Just did mine and absolutely love it, car handles exactly how it should have from the factory. No noticeable harshness or rough ride. Only mod is the springs.
Mach V lowering springs for Subaru BRZ and Scion FR-S lower your car approximately 0.75" in the front and 1.0" in the rear. They're 28% stiffer than stock in the front, and 30% stiffer than stock in the rear.
Instagram: BoostinIX
BoostinIX is offline   Reply With Quote
The Following User Says Thank You to BoostinIX For This Useful Post:
rikdrt1 (02-07-2013)
Old 02-07-2013, 09:41 AM   #5
jadewbj
jadewbj's Avatar
It all depends on what you are looking to get from the mod as Turn in said. In my experiences when you put just springs on factory struts will fail prematurely. How long it takes all depends on how good the struts are, driving style and roads it goes on.
If you are doing just the springs than I recommend you do the Koni Yellows at the same time. The labor involved to just switch the springs is almost identical to doing the springs and struts at the same time.
Just my .02.
jadewbj is offline   Reply With Quote
Old 02-07-2013, 09:50 AM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Tony
^^ this.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-07-2013, 01:22 PM   #7
wawro569
Drives: 2013 Scion FR-S MT
I just looked at the Koni struts and it looks like they're priced ~$200 PER strut, add another ~$230 for lowering springs then I dont see why not save a bit more for coilovers. Getting springs and new struts just seems redundant to be honest unless I'm missing something here.
wawro569 is offline   Reply With Quote
The Following User Says Thank You to wawro569 For This Useful Post:
Old 02-07-2013, 01:26 PM   #8
BoostinIX
BoostinIX's Avatar
Depends on the purpose, as everyone's said. Coils can be overkill for a lot of situations, and will adversely affect the gentle DD'ing.
Old 02-07-2013, 01:31 PM   #9
d1ck
Drives: Black 2013 FRS
That setup will be leaps and bounds better than any coilovers you can get for under 2k.
d1ck is offline   Reply With Quote
Old 02-07-2013, 01:57 PM   #10
wawro569
Really? I was under the impression that coilovers were the pinnacle of suspension upgrades?
Old 02-07-2013, 02:03 PM   #11
BoostinIX
BoostinIX's Avatar
Quality springs or spring/strut will aaaaaaaaalways be better than cheap coilovers
SubieNate (02-07-2013)
Old 02-07-2013, 02:09 PM   #12
OrbitalEllipses
Drives: Attitude
The pinnacle is not in the type of upgrade, but rather the QUALITY of the upgrade.
Koni's with RCE Yellows, Mach V springs, or any other QUALITY spring will ride better than $1000 BC coilovers that aren't custom valved.
Old 02-07-2013, 02:10 PM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Go for springs first, when you blow out your shocks (hey maybe it'll be 2 years down the road) get good struts. Get at least some camber bolts while you take those out and get an alignment after.
Cheap coilovers will eventually blow also and they aren't rebuildable...so there goes the savings of 'doing it right' the first time.
Rayme is offline   Reply With Quote
Old 02-07-2013, 02:16 PM   #14
BoostinIX
BoostinIX's Avatar
^ AND the ride quality will be craaaaaaap. Anyone that says Megan or BC ride great clearly haven't ridden with quality coils...
I'm on just springs and not too worried. Mach V's had the lower drops of the local options, shouldn't be too much harder on the shocks.
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 03:39 PM
Lowering springs HELP FRS_13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-27-2012 11:03 PM
Mach V Lowering Springs! Mach V Dan Brakes, Suspension, Chassis 0 08-01-2012 01:14 AM
Coilovers or lowering springs Hawk77FT AUSTRALIA 9 07-30-2012 10:41 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-11-2012 12:36 AM
