Old 02-14-2013, 12:52 AM   #1
BRZranger
Noise from front calipers after pad/rotor install
Wanted to tackle a first time brake pad + rotor install by myself. Luckily it stops no problem. During the test drive, there was no noise.
However, when I park it, jack it up, and rotate the front wheel by hand, I can hear slight rubbing of the pad and rotors.
Any thoughts?
I just uploaded the video to youtube, I'll post in a few minutes.
BRZranger is offline   Reply With Quote
Old 02-14-2013, 01:14 AM   #2
Pete156
I like to eat!
That's perfectly normal. They should be dragging just a bit which will cause friction which in turn will cause the noise. No worries.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
BRZranger (02-14-2013)
Old 02-14-2013, 02:12 AM   #3
BRZranger
[ame="https://www.youtube.com/watch?v=__pjRD5weLs&feature=youtube_gdata_player"]Front rotors rubbing brakes - YouTube[/ame]
I also finished the bedding process and I noticed the front brakes are emitting a lot of heat and a slight burning smell.
Otherwise the install went pretty easy. I skipped bleeding the brake oil / stainless steel line install for later.
I think this setup will work for now, maybe later upgrade to a bbk.
Just to clarify, I have front DBA t3 4000 series rotors, hawk HP+ front pads and HPS rear pads.
Old 02-14-2013, 02:32 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
All normal.
Old 03-24-2013, 12:46 PM   #5
ILoveMyFR-S
ILoveMyFR-S's Avatar
Drives: FR-S Raven
Have you had any problems with the rotor rubbing or is this normal experiencing he same thing here.
ILoveMyFR-S is offline   Reply With Quote
Old 03-24-2013, 12:48 PM   #6
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
normal
Huehuecoyotl is offline   Reply With Quote
Noise in front deck area Cowbun Issues | Warranty | Recalls / TSB 10 09-12-2013 06:24 PM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 05:55 PM
aFe Install, keep or loose noise generator jflogerzi Engine, Exhaust, Transmission 6 01-19-2013 06:50 PM
Front Rotor Specs - Yes i searched. njccmd2002 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 09-03-2012 01:58 AM
