Old 06-24-2017, 02:04 PM   #1
BadMOFO
BadMOFO's Avatar
Drives: 2016 Scion FRS Raven Black
07 STI Wheels??
I can get my hands on a set of Stock 07 STI Gold BBSs for basically nothing.. Was wondering if there would be any fitment issues at stock ride height.. as well as lowered with springs? I know that the STI Bolt Pattern is 5x114 and ours is 5x100. Now I do see adapters out there, but not sure which size would be best for front and rear? Any input would be appreciated. THANKS!
BadMOFO is offline   Reply With Quote
Old 06-24-2017, 04:19 PM   #2
gramicci101
Off Topic
You need conversion spacers. 2007 STi wheels were 17x8+53, 5x114.3 PCD, 56.1 center bore.
Spacers. Note that it's a pair of 15mm and a pair of 25mm. Wider goes on the back.
http://www.ft86speedfactory.com/isc-...l#.WU66KXgazCQ
This will effectively make the front wheels 17x8+38 and the rear 17x8+28. Both of which will fit just fine. You could run a 215 to a 235 tire with no issues. 245 will start to be pinched on an 8" wheel.
Edit- those are apparently on back order. Here's some more. http://www.b2autodesigns.com/product...oducts_id=9059
Old 06-24-2017, 04:28 PM   #3
gramicci101
Off Topic
There are 15mm ISC conversion spacers in the classifieds for a great price.
http://www.ft86club.com/forums/showthread.php?t=119626
Old 06-24-2017, 05:29 PM   #4
BadMOFO
BadMOFO's Avatar
THANK YOU! I appreciate the input brother. Wheels are a foreign language to me. haha
Old 06-24-2017, 05:36 PM   #5
gramicci101
Off Topic
Look at the stickies in the wheel and tire section. They get into technical descriptions about what each number means and how it relates to the whole. It's very useful, even just as background knowledge.
Here's what your wheels will look like. Yours would just be 15mm further out. He went with 2004 STi wheels because they're 5x100.
http://www.ft86club.com/forums/showthread.php?t=34789
Old 06-24-2017, 06:01 PM   #6
gramicci101
Off Topic
I forgot something. With 15mm spacers, the OEM lugs will still stick out a bit. Make sure the STi wheels have pockets on the mounting surface so the OEM lugs have somewhere to go. They should. If they don't, you have three options. 1: don't get the wheels. 2: get 25mm spacers; those will clear the OEM lugs so it won't be a problem. 3: dremel the OEM lugs shorter. I really wouldn't do this just to save money on wheels.
Old 06-24-2017, 08:28 PM   #7
mrg666
pessimistic skeptic
mrg666's Avatar
Old 06-24-2017, 08:36 PM   #8
gramicci101
Off Topic
That was in reference to point 3, not point 1. The original BBS STi wheels aren't my favorite, but they do look pretty good. And they clear larger brakes if that's something you're looking for. I personally want more of a dish on my wheels.
Old 06-28-2017, 11:09 AM   #9
BadMOFO
BadMOFO's Avatar
thank you guys.. I appreciate it!
*** VORDOVEN Forme 9 Wheels - New Lower Pricing for 2015! - Wheels IN STOCK *** Sonic Motor Wheels and Tires 218 03-24-2016 08:23 PM
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 04:55 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 03:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 11:08 PM
