Drives: FR-S,GTI
New clutch problem
My clutch quit on me again today. Driving along stepped on the clutch and it felt a little light. Next shift the clutch was gone. I managed to jam it into 3rd gear to get home. Now the clutch petal has no resistance, and it stays stuck to the floor. I'm on my 3rd TOB now so I know the symptoms, but I hope it's not that.
I'm thinking it might be a master/slave cylinder problem. With the petal disengaged there is some play between the clutch fork and the plunger. I can push back on the plunger to get even more play. With the petal stuck to the floor, there's no play between the plunger and the fork, but the fork hasn't moved. Any ideas on how to diagnose the problem? Has anyone had this problem before? And what did you do? The car has 240,000 miles on it and I DO NOT WANT to drop the tranny again. That is my last resort. |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | humfrz (12-18-2022) |
#2 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Well, if you put the pedal to the floor and the clutch fork hasn't moved, it sounds more like a hydraulic issue.
Look at your fluid level, look for a leak at the master cylinder rod inside the car, a slave cylinder leak inside the dust boot, try to bleed it see if it comes back. |
| The Following 5 Users Say Thank You to RZNT4R For This Useful Post: | humfrz (12-18-2022), soundman98 (12-23-2022), strat61caster (12-20-2022), WNDSRFR (12-18-2022), x808drifter (12-22-2022) |
#3 |
Drives: Crapcan
Try bleeding the system. If you have air in it, then the MC or slave has a bad seal and needs replaced. If it's not pushing fluid, likely the MC is bad.
The TOB could have seized, but that would have made quite a bit of noise and would have been noticeable. Clutch fork could have broke. You may be able to pop the boot out of the way and peak down there to check. Or stick your phone down and take a picture with the boot out of the way.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#4 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | WNDSRFR (12-18-2022), x808drifter (12-22-2022) |
#5 | |
Drives: FR-S,GTI
Great idea. Thanks. |
#7 |
Drives: FR-S,GTI
Well, my hopeful thinking didn't work out. I ended up having to pull the transmission again. 4th time. I sure hope it goes back together easier than last time.
Let's see if you can spot the problem. At least it wasn't the TOB this time. |
| The Following 5 Users Say Thank You to WNDSRFR For This Useful Post: | callisto (04-10-2023), DarkPira7e (12-23-2022), NoHaveMSG (12-22-2022), soundman98 (12-23-2022), x808drifter (12-23-2022) |
#8 |
Drives: FR-S,GTI
How can they build such a great reliable car with such a POS clutch mechanism?
And does anyone have a fork they want to sell? No I'm not getting the Versus. |
#9 |
Drives: Crapcan
I have a used stock fork you can have, just PM me. I'd check with a dealer though, they can't be that expensive and might be just as fast.
#10 |
Drives: FR-S,GTI
Thanks for the offer NoHaveMSG. I checked and the clutch fork SU003-00803 cost $21.05.
So I think I'll just go with a new one. The clutch disk SU003-00799 cost 69.57. The pressure plate SU003-00800 cost 139.29. And the TOB SU003-00802 cost 16.16. Anybody see a pattern in the part numbers? I wonder what a SU003-00801 is? |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | NoHaveMSG (12-22-2022) |
#11 | |
Drives: Crapcan
00801 the pivot maybe? The subaru part numbers are different so my part number reference that I usually use doesn't match up.
#12 |
30 minute maintenance
Drives: My18 wrxsti
#13 | |
ProCrastinationConsultant
so if those single-vocal-poster threads are the main reason you don't want the verus, i think your trust is misplaced. but stock is definitely cheaper and up to the job.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#14 |
Drives: 2013 frs base
Is that the original fork? If so, 10 years and 240,000 miles ain't too bad. Given the history of this component in the older twins, it would prolly be a good idea to change the fork and pivot whenever you change a clutch.
| The Following 3 Users Say Thank You to blsfrs For This Useful Post: |
| Clutch or transmission problem? | 86runner | Engine, Exhaust, Transmission | 13 | 04-12-2022 08:34 PM |
| SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB | zc06_kisstherain | Transmission and Driveline | 3 | 10-17-2018 11:31 PM |
| ACT Clutch Adjustment Problem | Shady195 | Engine, Exhaust, Transmission | 17 | 10-20-2016 03:42 PM |
| Clutch problem? | Pele86 | Engine, Exhaust, Transmission | 13 | 06-04-2013 11:58 PM |
