| Software Tuning Discuss all software tuning topics. |
Drives: 2020 Subaru BRZ AT
Dealership scheduled warranty maintenance soon..
Should i flash back to the stock tune for a scheduled warranty maintenance oil change and an alignment? ive seen people say when u take it to a dealership for anything u should flash back to stock? its a new car btw with only 13000 miles on it
#2 |
Drives: 2019 Toyota 86 TRD SE
I didn’t. I’ve got a 2019.
#3 |
No, Scheduled maintenance is still covered. By tuning you just do not have an warranty on your drivetrain anymore.
#4 | |
Drives: 2020 Toyota GT86
In my case, being at over 5000 feet above sea level, my car with a header and tune still has less horsepower than what the car has at sea level. So if I ever do have a problem I'd love to see them try and prove that my header/tune was the root cause
This post sent using 100% recycled electrons.
#5 |
ProCrastinationConsultant
your technically right. but there's been plenty of cases where the only way to get to that technicality is with a jury...
#6 | |
#7 |
The concern is that if they flashed the ecu for some reason it will screw you up. So two ways to protect yourself.
1. Flash back to stock 2. Tell them not to touch the ecu other than a reset. This is basically telling them you tuned it. For my cars I am out of warranty, so it does not matter. |
#8 | |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Less power due to altitude, not because of the tune silly. Meanwhile starting this Oregonian sweat a bit with Gavin, Kate and Jay being so close and all in their implementation of Gavin's bullshit. |
| The Following User Says Thank You to jeepmor For This Useful Post: | Jdmjunkie (11-05-2021) |
#9 |
Drives: brz 2017 hksv2
dealers can only upgrade available newer rom
99.9% your car doean t have an available upgrade so they won t flash anything they can t even reflash the same tune and that s why they just swap ditectly with a new expensive ecu if they think the problem is in the ecu in the case there is a newer rom for your car and they flash it with techstream/SMIII, if OFT then it will override your tune and brick your OFT, if Ecutek they won t be able to flash due to ecu lock |
#10 | |
Drives: FT86
Correct ecutek or brzedit tuned cars dealer canooth flash they would jist swap ECU OFT or tactrix they can flash neither system will care. OFT only checks calid of tuned loaded to oft via openflash manager. Then it check vin of car, it doesnt actually check calid of tune in car , so it wont effect oft if dealer flashes new calid, but oft will jist overwrite with old calid next time you flash with oft |
#11 |
Drives: 2019 Subaru BRZ
When dealers upgrade to a newer ROM, do they go a full letter up from e.g. S10C to V00C, or can they only go from S10C to S11C?
#12 | |
You took the car out of its intended parameters of operation. A non-factory tune is a 100% guarantee that they can deny warranty coverage. |
#13 |
Only if they can directly connect it as a root cause of the issue.
| Dealership wants maintenance in my 51km BRZ | TMXSTAR | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 12-05-2016 12:27 PM |
| Scheduled maintenance in San Diego | trailofdead | Southern California | 7 | 05-24-2015 07:18 PM |
| subaru scheduled maintenance | mike the snake | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 11-28-2014 07:23 PM |
| Complimentary maintenance + tuned ECU, will the dealership know and void my warranty? | retrosmiths | Issues | Warranty | Recalls / TSB | 4 | 08-07-2013 08:27 PM |
| Best Dealer for Free Scheduled Maintenance in SOCAL Area? | nyanpire | Southern California | 6 | 08-09-2012 09:40 PM |
