STX setup sharing thread (2021)
Well, the last one was pretty well received, so here's the 2021 thread starter.
No, really, *this* year I'll put the coilovers on the car! I have collected some small bits (sway bars, engine/trans mounts, etc), so really, this time I mean it ![]() Opinions on the KW V3 coilovers? --Bryan
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
| The Following User Says Thank You to Autoxer62 For This Useful Post: | smg1138 (01-04-2021) |
#2 |
Drives: 2016 Scion FRS
I'll put my setup on here.
I threw the car together last March, then only got to run a couple of events all year. 2016 Scion FRS - ProParts Megan Racing coilovers - using Megan camber plates and front end links - 400/400 springs - Eibach 25.4mm hollow front sway bar (leftover from SSC set up), set on soft - Mann rear bar - Racer X rear end links - SPC rear arms with DIFtech bushings - JDL 4-2-1 EL header - JDL OP/FP combo - Invidia Q300 catback - Perrin inlet tube - Xero Limit Ecutek tune - Whiteline transmission insert - Whiteline subframe bushings - 17x9 RPF1's +35 offset - 245/40/17 A052's Car was too low and I need to shift the front subframe to get the camber numbers I want up front. Never got around to it with Covid and then Nats getting cancelled. I've got an Anti-Gravity ATX20 Restart and Mele Battery Box waiting to go in the car and I may do a few other things. Hope to run a "normal" schedule for myself and my co-driver, which would be about 8-10 national events, and whatever locals I can hit at Bristol/ZMax/Huntsville, but kind of in limbo with Covid and possible travel restrictions related to my job and I'm having a lot of fun throwing frisbees. Hopefully, STX numbers make it worth traveling. |
#3 |
Copy and paste from 2020 with a couple updated items. I won't be running STX for 2021, I'm codriving within SSR. Anyways my car has a flex fuel kit going on it for E85 and track use. I think my days in STX are done.
2016 Scion FRS: Suspension: MCS 2W Remotes - Custom Revalve & Coated Piston 400/350# Rates Raceseng Camber Plates/Raceseng 1" Top Hats in Rear Front: -4.2* Camber, 0 Toe Rear: -2.5* Camber, 1/16" Total In Ride Height - Front Wheels 25" from floor to center of fender above wheel. Rear set for 1/8" Rake Karwan FSB Mann Rear Bar set of Stiff (I adjust all the time though). RacerX Endlinks RacerX LCA Whiteline Subframe Insert Bushings STi Engine Mounts Engine: aFe Momentum Intake JDL 4-2-1 Header JDL Ultra Quiet FP/OP Combo w/Cat Perrin 2.5" Exhaust MotoEast/XeroLimit Custom Dyno Tune Perrin Oil Cooler Wheels/Tires/Misc AP Racing BBK w/Ferodo DS2500s RPF1s 17x9 +35 with 245/40/17 RivalS 1.5s + Yokohama AO52s Antigravity 680CA Battery w/PFTuning Tray Grimmspeed Master Cylinder Brace
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | smg1138 (06-01-2021) |
#4 |
Drives: Many
I'm running STX again and probably for the next year or two, realistically. Don't want to switch to a 'big tire' car and the ownership costs for this car seem pretty low now that I've spent the money on parts. (I also have an s13 track day car, a miata with vvt/xidas/etc, and a fiesta ST daily driver, so the brz is the simple one).
Suspension: MCS 2W remotes 5k/9k (275/500) rates Raceseng CasCam front plates, 1" top hats in rear Karcepts Front bar Mann rear bar Alignment is generally -4.2ish*/-2.1*ish camber, 0 / -1/16" toe. Racerx LCA with a delrin bushing (instead of poly) Racerx Rear endlinks Engine: Cosworth or k&n drop-in filter Ace A350 header JDL Ultra quiet front pipe CSG touring86 exhaust Perrin oil cooler Other: OS Giken lsd in 1way config Whiteline subframe, diff and trans inserts STi motor mounts I run a few different sets of konigs 17x9 +40 with 245/40s. I mix between rivals and a052s. Still run a heavier miata battery because I had one laying around when the 35lb beast died. Maybe I'll buy something fancy this year. Stock brakes with Stoptech pads f/r. |
| The Following User Says Thank You to e1_griego For This Useful Post: | smg1138 (06-01-2021) |
#5 |
Drives: 2013 Raven FR-S
What kind of caster are you guys running for AutoX? I’m looking at finally getting some camber plates for my Tarmac 2’s. Been running them with stock top hats for years and am maxed out at -2.7 with the crash bolts. Not sure if I really need any additional caster adjustment or not though. I’ve heard too much can cause issues with the power steering?
#6 |
Drives: Many
I want to say mine is basically at stock caster -- is that 6*? I can't really remember.
| The Following User Says Thank You to e1_griego For This Useful Post: | smg1138 (01-05-2021) |
#7 |
Drives: Miata
I prefer less caster.
With a lot of caster I feel like I'm picking up the inside front of the car with the steering wheel. When I drove the 914-6 in my avatar I could barely finish the run the steering was so hard. I told the owner it felt like a lot of caster. We popped the hood and saw the caster was maxed. |
| The Following User Says Thank You to racingfool For This Useful Post: | smg1138 (01-05-2021) |
#8 |
Purist
Drives: 2013 FRS - Hot Lava
What is the purpose of the Mann rear bar? Ive read its softer than stock? Does it have to do with the Torsen diff, or is it just to keep the rear planted on heavy turn in for autocross? Would it be beneficial in a "touge" setup? (tight hilly backroads)
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
| The Following User Says Thank You to Westen86 For This Useful Post: | smg1138 (01-05-2021) |
#9 | |
- There are 3 settings, the stiffest setting is supposed to be equal to stock. - I don't see any reason to run a larger rear bar on the car, regardless of diff. Yes, it allows the rear suspension to articulate. - Over a stock bar? Not really. Over a bigger rear bar? I think so. I drive my car on the Tail of the Dragon maybe every month or two. Rear bar is just a part of the equation, but the car is much more predictable with a lot less computer intrusion with the current setup compared to the SSC set up with the Eibach rear bar. |
#10 | |
Drives: '13 FRS - STX
| The Following User Says Thank You to strat61caster For This Useful Post: | smg1138 (01-05-2021) |
#11 |
Drives: 2017 BRZ series.yellow
Still in STX with mostly the same as last year.
2017 w/ performance pack RCE T2's Camber/caster plates -3.8 camber (probably going to push up to -4.0 - -4.2) 7.2 caster 0.0 toe Hotchkis 1" hollow front bar Rear LCAs -2.5 camber 0.4 total toe in UEL header, catback, OFT tune 255/40 A052's Adding: Various bushing inserts, trans, diff, rear subframe. Overpipe Inlet hose Thinking about switching to Hotchkis rear adjustable sway bar. Looking for more predictable rotation with the rear end. |
| The Following User Says Thank You to Breezio For This Useful Post: | Racecomp Engineering (01-06-2021) |
#12 |
Drives: 2017 BRZ Premium
Hopefully get the car a bit more dialed this year:
2017 BRZ Base Ohlins MI20 R&T's from Works Motorsports - 6KF/7KR Blox LCA (Poly bushings) Whiteline 24mm front bar (Soft) Whiteline front endlinks Whiteline Trans mount insert -3* F -2*R Camber (Increasing to 3.5-4F / 2.5R for 2021) 6.5* Caster 0 Front toe 1/8" Total rear toe in Ace350 Motiv catted Front pipe CSG Touring86 Catback Tuned by Zach @CSG 17x9 Hypergrams 245/40r17 RE71R's (Will try Ao52's for 2021) Adding 2021: Whiteline sub frame inserts Whiteline diff Inserts JR Oil Cooler Engine mounts - Brand TBD |
#13 | |
I have Raceseng Plates with the +1 of caster. So I have it set to that with whatever that ends up being. I have never measured it, I don't really care not knowing what it is. I think it's worth it to try and gain as much dynamic camber as you can. I personally have not dealt with power steering issues aside from hitting NCM Faux Rouge at 114 MPH and loading up the car (at at sinkhole)
Kyle H. - #89 STX
| The Following User Says Thank You to M0nk3y For This Useful Post: | smg1138 (01-06-2021) |
#14 |
Drives: 2015 CWP BRZ
I’m pretty much the same setup as last year. And if I remember right I’m right about stock caster settings. I tried running a ton of caster and didn’t like how the car felt in slower transitions.
Power mods: Grimspeed intake, Tomei UEL header and overpipe, highflow cat/ front pipe,Kartboy crank pulley, OFT tune. Suspension: RCE T2 400lb front 500lb rear springs. Whiteline 20mm front bar on stiff setting Mann rear bar(settings depends on surface) -4.2 front camber with 1/16th” toe out -2.5 rear camber with 1/16th” toe in AP Racing Sprint front kit with Ferrodo DS2500 pads front and rear. OS Giken LSD with the Lugod specs Rear subframe and diff insert bushings. Light weight battery. 17x9+35 RPF1 with 245/40R17 Yokohama A052 or Falken RT660 for local events. |
| The Following User Says Thank You to bslate3 For This Useful Post: | smg1138 (06-01-2021) |
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 03:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 02:40 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 12:27 PM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 12:30 PM |
