Old 01-02-2020, 05:26 PM   #1
gtsnipe
Drives: '13 BRZ
Which Coilovers to purchase 1500 Budget.
My only concern is comfort and having a tad of low. My BRZ is my daily.
Any information is greatly appreciated.
gtsnipe is offline   Reply With Quote
Old 01-02-2020, 05:32 PM   #2
Gazzabean
Drives: Toyota GT86
BC Racing BR coilovers. I’m rocking them, they’re great. Completely dropped
Gazzabean is offline   Reply With Quote
Old 01-02-2020, 06:01 PM   #3
HaXx
Drives: jrsc_brz
do you want new or used. you can get a set of slightly used (5kmiles) coils for 1000 that were new 1500-2000. especially if ur in cal. the used marketplace there is poppin
HaXx is offline   Reply With Quote
Old 01-02-2020, 06:04 PM   #4
new2subaru
Weight Weenie
Drives: 15 FR-S
lowering springs
The Following 3 Users Say Thank You to new2subaru For This Useful Post:
Leonardo (01-02-2020), NoHaveMSG (01-02-2020), wparsons (01-06-2020)
Old 01-02-2020, 06:08 PM   #5
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
I got a set of coils and camber plates for 2000. Good travel. Gest adjustment and the spring rates won't kill your back but they can double duty for track and autox. Whiteline maxg
Clutch Dog is offline   Reply With Quote
Old 01-02-2020, 06:52 PM   #6
norcalpb
norcalpb's Avatar
I have STi springs on Bilstein B6 dampers with Pedders front Top hats ~ $1250 brand new.
It is so comfortable to daily drive. It soaks up all the crappy roads around me and provides a pretty decent level of performance. The springs will only lower the car 10mm, so it may not be ideal if you’re looking for the super low. But this also means you have more travel than nearly all other springs which imo is critical to comfort on this chassis.
For track this setup isn’t the best due to soft and progressive spring rates, but it’s not bad at all.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
churchx (01-02-2020), Stomachbuzz (01-03-2020)
Old 01-02-2020, 07:37 PM   #7
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
BC Racing BR coils for about 2 years so far and love it!
+ Great for daily driving, depending on spring rates.
+ Gives more clearance for aftermarket wheels.
+ Can adjust preload, height, and dampening however you like.
You may need to get some aftermarket LCA's/Camber bolts to have proper camber
KMA KiCKz is offline   Reply With Quote
Old 01-02-2020, 07:51 PM   #8
Infinity
Drives: 2016 Scion FR-S
The 2 best options in that price range are Racecomp Engineering Superstreet-1 and Counterspace Garage Spec Tein Flex-A.
Infinity is offline   Reply With Quote
The Following 8 Users Say Thank You to Infinity For This Useful Post:
churchx (01-02-2020), Clutch Dog (01-03-2020), CSG Mike (01-03-2020), Dzmitry (01-03-2020), finch1750 (01-02-2020), Racecomp Engineering (01-02-2020), wparsons (01-06-2020), yelsew (01-06-2020)
Old 01-02-2020, 08:26 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
How low is a tad low? RCE, TRD, or Swift Sport Springs on OEM or Bilstein struts would be great in the budget range. The 2 options @Infinity gave are great, though I would get the standard flex A over the CSG spec for a DD. ST coilovers would be good too for daily driving only.
Old 01-03-2020, 12:58 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Compared to what?
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
finch1750 (01-03-2020), wparsons (01-06-2020)
Old 01-03-2020, 01:00 AM   #11
Captain Snooze
Drives: Red Herring
I doubt it.
Old 01-03-2020, 01:58 AM   #12
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
KW V1, ST XTA, or RCE Superstreet 1 (all kw variants) on stock top hats for comfort and slight lowering.
If you aren't looking to go wider than 8.5" wide wheels, then i recommend stock top hats with Bilstein B8 shocks on 1" lowering springs such as RCE Yellow or B6 on stock springs for normal ride height.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 01-03-2020, 02:55 AM   #13
finch1750
finch1750's Avatar
Originally Posted by Spawn_Of_Creation View Post
KW V1 on stock top hat for comfort and slight lowering.
Bolded for emphasis. Oem top hats make a huge difference. You can still get enough camber for daily or even mountain runs other ways
Old 01-03-2020, 04:21 AM   #14
Gazzabean
Drives: Toyota GT86
Compared to what?
Not compared to anything. They’re just perfect for adjustment, and as for camber; they create PLENTY of it when slammed. I am however, converting to air if that’s something you’re interested in. Definitely over the budget, but might be worth it, I have an issue getting over speed bumps and the like. So parked I can slam the car and driving I can raise it, all from the press of a button, if I don’t like the drive on track or even on fast roads, I can always convert back and keep them for show days and whatnot.
One more thing, the rebound on these coils is second to none. Spot on adjustment, perfect round fast bends, just don’t put them too stiff or you’ll hop round the bends. That’s what used to happen to me, no understeer and no oversteer, just hopping. Not ideal really but sets off your LSD so loss in power round bends is annoying.
brz, coilovers, comfort
What coilovers should I purchase? 403 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 71 05-20-2017 04:09 AM
Ohlins Coilovers - $1500 Shipped Bobby@Forged Brakes, Suspension, Chassis 1 09-28-2016 06:38 PM
isc n1 coilovers and 19x9.5 rays 57extremes 1500 miles mint kingkai23 NY / NJ / CT / PA 1 08-10-2014 12:11 PM
Eibach Multi PRO R2 Coilovers: $1500 FRSdrive Brakes, Suspension, Chassis 11 02-24-2014 08:00 PM
$1500 budget coilover - what would you choose? smbstyle Tracking / Autocross / HPDE / Drifting 27 11-17-2013 10:35 PM
