Drives: 2014 White BRZ Limited
Hi guys, so my 2014 BRZ keeps dying, even today, I drove it for 45 mins straight, parked and then tried starting it up right after, and the battery is completely dead. Not sure if related but my dashcam had been left plugged in (hotwired) for about a week, I don't drive my car too often so I jumpstarted it and ever since that day, i'm able to jump start the car, drive it but once the car is off, it won't start. Not sure if alternator is not charging the battery and the battery is not keeping it's charge. It's only got 19k miles. Any ideas?
Ps. I have nothing being left plugged in, no electrical mods or anything, I even removed the dash cam and still doing that. |
#2 |
Battery. The BRZ battery seems to have a very short life and is a well know issue. Grab a new one and all will be good.
#3 |
Drives: 2014 BRZ Limited
Anybody have a suggestion for a good battery? (Not some stupid lightweight motorcycle battery not designed for this car, but a long-lasting, reliable battery for a daily driver.) I haven't seen a good battery discussion in a while, and I'm wondering if there's anything new (that isn't a stupid lightweight firestarter).
| The Following User Says Thank You to extrashaky For This Useful Post: | Tcoat (03-09-2017) |
#4 |
Drive From Home
Drives: BRZ STI Performance
Did you top up the battery with distilled water from time to time?
I've had a similar Panasonic battery in the EK Civic and we never topped it up cuz we didn't know, only lasted 3 years lol! Topped up occasionally should last forever. Humm what about Optima AGM battery? |
#5 | |
#6 | ||
http://www.ft86club.com/forums/showthread.php?t=82887 http://www.ft86club.com/forums/showthread.php?p=1728041 http://www.ft86club.com/forums/showthread.php?p=2822872 http://www.ft86club.com/forums/showthread.php?p=2681746 I could go on for hours. The good news is that most were indeed covered by warranty.
#7 |
Drives: '15 BRZ RA
I am using a Yuasa battery www.yuasabatteries.com or www.gs-yuasa.com
I have the 44B19L which is smaller and is considered an Auxiliary/Starter Battery. It is used as OEM battery in Lexus and Mercedes E & S class hybrids. It is one of the top brands. They have also a catalog here: http://www.gs-yuasa.com/en/products/...adeinJapan.pdf Better to call them and ask if they have a battery for your needs. Last edited by nikitopo; 03-09-2017 at 12:09 PM. |
#8 |
charge your battery and hook a volt meter up to the battery while the car is running. If its over 13 volts then your alternator is working. If it shows under 12 and dropping then something is wrong with your charging system. You could have also blown a fuse with the dashcam.
2013 BRZ Limited current mods: TD05 20g turbo - Invidia over pipe and catted down pipe - Magnaflow catback - Enkei Fujin wheels. BFG comp 2 A/S 225-45-17.
#9 |
I'm running Diehard Advance Gold AGM batteries in my Jeeps and have had no complaints at all, but last time I checked Diehard didn't have the AGM battery in the BRZ's size. My battery usually does fine when I drive the car regularly, but I'd like a battery that doesn't need a jump if I leave the car parked for two weeks.
#10 | |
Following all the battery issue threads I see that the BRZs have issues at about a ten to one rate over the FRSs. When you consider there are far fewer BRZs to start with this number is significant even in the relatively small sample size of the forum. There is something about the BRZ that is creating a patristic draw and draining batteries faster than the FRS. I just don't know what that is.
| The Following User Says Thank You to Tcoat For This Useful Post: | Clipdat (03-09-2017) |
#11 |
so went to the dealership today, guy told me it would about 1-2 hours to have my battery tested it, I waited on hour and my boss kept messaging me about getting some stuff done asap...so had to postpone it until Monday, not my day.
| The Following User Says Thank You to edigeek For This Useful Post: | Tcoat (03-09-2017) |
#12 |
Drives: 2013 Rally Blue BRZ
My stock BRZ just started going bad recently. I couldn't listen to the radio with the car off for more than a few minutes and still start the car. Ended up just replacing it with an Optima red top but at the end of the day most batteries are the same. My truck has whatever brand they sell at Wal Mart and it holds a charge surprisingly well for how long I have to sit there cranking on it.
#13 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Sportsguy83 (03-09-2017) |
#14 |
Drives: 2014 FR-S Asphalt
I only got about 18 months out of my first battery. One day it just would hold a charge, and I had to get jump started to go anywhere. It was replaced under warranty. They are warrantied for 2 years.
| Help! Battery died, charged battery now getting all sorts of error codes! | jermyzy | Issues | Warranty | Recalls / TSB | 12 | 11-25-2015 01:35 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 09:26 AM |
| Battery tray for Braille 21lb battery? | lordtakuban | Engine, Exhaust, Transmission | 4 | 09-10-2013 09:55 AM |
| TR-B1500 battery and billet battery tray install. | mines13 | DIY (Do-It-Yourself) Guides | 8 | 12-07-2012 04:59 PM |
| Weak battery or bad alternator from factory? | empower-auto | Issues | Warranty | Recalls / TSB | 2 | 09-21-2012 03:17 PM |
