| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Asphalt Scion FR-S
Coolant Temps WAY TOO HIGH
Hi. I know, use search, blah blah. Don't got time I'm on side of road.
Was driving tamely and my AC started blowing warm. I live in Orlando, and I'm chubby. My AC is ALWAYS on. About 5 minutes ago my coolant temps shot up to 240 and my AC started blowing like an oven. I immediately pulled over and shit the car down and topped off my coolant. Gave it a full chance to cool off. Started her back up but the temps are starting to climb again. So, cracked radiator or something else? Sent from my iPhone using Tapatalk
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
#2 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
no visible leaks?
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#3 |
Off Topic
First: topped off your coolant with what exactly? Random coolant from Autozone, or vehicle-specific coolant from Toyota or Subaru?
Second: do your fans cycle? Third: Does the water pump work? |
#4 |
![]() Sprayed all over the header. Up on hood. Fans. Small puddle once I pulled over. Sent from my iPhone using Tapatalk
#5 | |
Prestone 50/50. Been using it for two years already. Fans are cycling. Not sure how to make sure water pump is working. Sent from my iPhone using Tapatalk
#6 |
Sarcastic SOB
Warranty
#7 |
Car is at 40k. And I was second owner Sent from my iPhone using Tapatalk
#8 |
Also could I possibly be looking at a thermostat problem? Perhaps it's not kicking.
#9 |
try to find the source of that leak.
#10 |
Everything is still wet and it's dark. I'll have to check in the morning
#11 |
Huge E85 fan!
Drives: 2016 Scion FRS
There's a reason we're supposed to use the ridiculously over priced OEM coolant. Generic off-the-shelf stuff like Prestone is liable to cause a problem.
If you crank the heat (no AC, full on heat on high) does that help your coolant temps? When you topped off the coolant, how low was it? What sprayed all over the place? Coolant? How hot did your oil temps get? |
#12 |
Oil didn't pass 170 which I'm hoping is normal. Coolant went everywhere. I'll try the heat thing now and get back to you guys
#13 | |
No luck. The heat on max and coolant started climbing past 215 while idling Sent from my iPhone using Tapatalk
#14 |
The thermostat may be stuck closed .....if so replace.
To find the leak, I suggest you fill it up with "water" and find out where it's leaking. ...... drain water. Fix leak. Re-fill with the OEM blue stuff. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Toyarzee (08-19-2016) |
| Coolant Temps Running High | Dezoris | Tracking / Autocross / HPDE / Drifting | 43 | 09-29-2016 12:58 PM |
| High coolant temp at idle with A/C off | extrashaky | Issues | Warranty | Recalls / TSB | 11 | 11-11-2014 05:50 PM |
| Anyone notice this car eats coolant at a high rate? | Liquidsnake | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 04-23-2013 05:25 PM |
| Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 04:17 PM |
| ECU pulls timing at high oil temps? | brillo | Engine, Exhaust, Transmission | 24 | 03-31-2013 10:10 PM |
