Old 04-14-2016, 01:24 PM   #1
nexusatm
nexusatm's Avatar
Drives: GT86
compression ratio
Hello people, tell me please what i need to make compression ratio 10 or 9.5? What parts i must to buy? Are there kits aviable for this action? (sorry for my english)
nexusatm is offline   Reply With Quote
Old 04-14-2016, 02:22 PM   #2
denso
Drives: 86
If you want to lower your CR you have to get a new set of pistons.
Your power goal should be known if you want to lower your CR.
denso is offline   Reply With Quote
The Following User Says Thank You to denso For This Useful Post:
go_a_way1 (04-14-2016)
Old 04-14-2016, 03:03 PM   #3
nexusatm
nexusatm's Avatar
Drives: GT86
What about connecting rods?
Old 04-14-2016, 03:06 PM   #4
Andew727
Drives: Scion FR-S
there are a few ways... even a thicker head gasket can lower compression... pistons are the way to go.
Andew727 is offline   Reply With Quote
The Following User Says Thank You to Andew727 For This Useful Post:
nexusatm (04-14-2016)
Old 04-14-2016, 05:34 PM   #5
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
definitely replace the rods too
the stock items are weak and very variable in strength as they are a sintered part
Matt@Cosworth is offline   Reply With Quote
Old 04-18-2016, 09:12 PM   #6
SPCorBUST
SPCorBUST's Avatar
Does anyone know how lower compression pistons affect emissions? I think I'd like to use lower compression pistons but I'm concerned that I'll no longer be able to pass a smog. California CARB is a PITA.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-18-2016, 11:47 PM   #7
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
You shouldn't lower your compression ratio without first consulting your tuner on the benefits and cons for both keeping stock compression or lowering it, also for the amount of power you want to push out of the engine.
Personally for my build i'm staying with the stock compression with some (Custom CP Pistons, and Carrillo H Beam rods) because I don't think the trade offs you get with lowering your compression is worth it.
i.e. Lower gas mileage, lower grade fuel(usually), and etc.
But if you want to lower it, all you need is some low compression pistons from either (CP, JE, Arias, Manley, and etc just to name a few) just to name a few.
R2RO is offline   Reply With Quote
The Following User Says Thank You to R2RO For This Useful Post:
wparsons (04-22-2016)
Old 04-19-2016, 12:07 AM   #8
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Or you can just run a stock internals with not a shitty tune and be fine to 450whp with e85 and 18psi. You should be blowing trannies before blowing blocks.
The Following User Says Thank You to boredom.is.me For This Useful Post:
DriftinFRS (04-25-2016)
Old 04-19-2016, 12:30 AM   #9
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
The Following 10 Users Say Thank You to Luftwaffel For This Useful Post:
AJPG (05-09-2016), bobio64 (04-19-2016), boredom.is.me (04-19-2016), Dream20b (04-19-2016), DriftinFRS (04-25-2016), D_Thissen (04-22-2016), R2RO (04-23-2016), sato (05-11-2016), weederr33 (05-09-2016), xkalelx (04-19-2016)
Old 04-19-2016, 12:34 AM   #10
CSG Mike
CSG Mike's Avatar
450whp won't last forever, no matter how good your tune.
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
Dream20b (04-19-2016), FRS Justin (05-10-2016), Luftwaffel (04-19-2016), R2RO (04-23-2016), spitfire481 (04-19-2016), Toyarzee (04-22-2016), wparsons (04-22-2016)
Old 04-19-2016, 01:11 AM   #11
boredom.is.me
Custom User Title
200 won't last forever either.
@Reaper
Old 04-19-2016, 05:14 AM   #12
Northwest86
Drives: Velocity Orange 86 GT
13:1 or gtfo.
Northwest86 is offline   Reply With Quote
Old 04-22-2016, 01:53 PM   #13
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
We have 2 cars locally racing time attack and still street drive. One is stock rods 13.5-1 at 400+whp and the other is all stock 450whp for 27,000 miles. Lots and lots of broken transmissions right now. Not much racing until sequentials come in.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
CSG Mike (04-22-2016), DriftinFRS (04-25-2016)
Old 04-22-2016, 02:05 PM   #14
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Dont do it, unless you want to lose power.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
R2RO (04-23-2016)
Suggestions on built short block and compression ratio? SoCal80six Forced Induction 24 11-18-2015 05:59 PM
Porsche Patents a Variable Compression Ratio Captain Snooze Other Vehicles & General Automotive Discussions 7 04-30-2015 11:21 PM
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
