Member's Car Journals Car journals by our members. |
#85 |
Drives: Toyota GT86
So after 8 track days on 215/45/17 Pilot Spot 4 I am upgrading to a semi slick(200tw) tire. The new setup is Braid full race A 17x8 ET35 with a 225/45/17 Potenza Race tire. I am very excited for my track day on Thursday !
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#86 |
Drives: '22 BRZ
Man, that will be such a big improvement! Curious what you think!
The Following User Says Thank You to DocWalt For This Useful Post: | autoracer86 (06-19-2024) |
#87 |
Drives: Toyota GT86
June 20th Track day
Track Temp 65F/18.3C Max Speed: 95MPH/ Up from 93.9MPH/152KMH Max RPM: 7417 Up from 7366 Max Brake Pressure: 966PSI Up from 796PSI Seemed to use a bit less brake pressure in the afternoon. Probably over braking in the morning. 815PSI/852PSI/871PSI Max Oil Temp: 253F/122.7C Max Coolant Temp: 205F/96.1C Oil Pressure: 27.2PSI - 56PSI AVG 44.5 Seeing oil drops in turn 7(right hander)with semi slicks.
#88 |
Drives: Toyota GT86
Bit of a long post but if you wanted a bit more detail here it is...
My best lap of 2:05.4 is 2.3 quicker than my previous best on the ps4 tires with coilovers. I left about .6 on the table so the new tires seem to be closer to 3 seconds quicker than the ps4. Over the 8 corners I did improve each corner was anywhere from .2 to .5 faster. There were 2 places turn 2 no improvement and turn 3 where I was slower by .3 so assuming a gain of .3 for those corners there could be another second improvement over the ps4. But as of now 2.3 is the improvement I found from the traction mod and new wheel/tire package. What I find a bit strange about all of this is I haven’t seen much improvement from my suspension upgrades and alignment. 2:07.9 was my best lap with a completely stock car on ps4 tires. Best I could manage with my suspension upgrades before the traction mod was a theoretical of 2:07.7 traffic messed up my fast lap but man I though I setting a new personal best would of been a lot easier with the suspension upgrades. Now who knows maybe the ps4 tires were already past their prime by the time I got the upgrade causing my lack of pace but now I am on new tires that should be around 3 seconds faster and that’s about what I found. I feel like I could have just tossed these tires onto a stock gt86 and ran the same time. They do say tires are the most important upgrade so... Driver is definitely factoring in here there are spots on the new setup where I just simply broke too soon or too hard. I think the issue is coming from the increased speed into the braking zone it’s just making me a bit nervous so I am over slowing. My goal with this setup is going to be something in the 2:03s that would be an overall 4 second improvement over the car when it was stock. Some other take aways from the new tires. The grip level is definitely increased you can feel it and see it in the data but no surprise there. Was much more stable in the sweeping right hander(turn 5) sticky tires and traction mod working together ha. They held up fine and I didn’t feel as if they got greasy. Tested with 32psi and 30psi hot never got close to the triangles so maybe I can go even lower. First set of semi slicks(200tw) tires in like a decade so I can’t really compare them to anything else sorry. I am not sure I am pushing hard enough to really comment on if its feels pushy or loose but I would say its does seem like a tight setup the back end just won’t move much but maybe that’s due to my driving. Also not sure making the car rotate more would be any faster for me at this point but I could see myself upgrading from stock sway bars. I started to feel the power steering cut people talk about never had that with the PS4. Oh and the traction control light flashed a few times in turn 3 when using my normal 5 second hold. Again also new and didn’t flash anywhere else not that I noticed anyway. More grip More Speed More tire Just a few data points Braking Force is up from 0.77 to 0.87 Corner force is up from -1.26/1.14 to -1.34/1.66 Gsum is up from 1.31 to 2.02
#89 |
Drives: Toyota GT86
Screenshot from race studio showing the oil pressure drop from the added grip. This is a right hand corner. Its the double right hander turn 7 if you care to find the spot on my videos
#90 |
Drives: Toyota GT86
Just a photo dump of tires lol Tested 32PSI hot then 30PSI hot
The Following User Says Thank You to autoracer86 For This Useful Post: | villainous_frx (Today) |
Scratchy Noise and Peddle vibration | Sovereign | Issues | Warranty | Recalls / TSB | 7 | 07-19-2022 05:36 PM |
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
JC's hot lava/burnt orange 2014 GT86 build thread | GT86NZID | Member's Car Journals | 11 | 08-25-2016 10:41 PM |
Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
Orange you glad you checked this thread?!? | BlaineWasHere | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 23 | 04-09-2013 05:02 PM |
