Old 01-13-2013, 08:15 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
what's your solution to reduce the wheel well gap?
in stock form, the wheel well gap looks too big for my taste. i wanna see what everyone here is doing about it? bigger wheel? lower car?
if we change to a bigger wheel, do we need to take it to the dealership to have the computer readjusted?
if we lower the car, do we need to get alignment done?
What's the cost of doing each?
chenshuo is offline   Reply With Quote
Old 01-13-2013, 08:19 PM   #2
Burrcold
Drives: Subaru BRZ Limited
Changing rim size will not really decrease the gap, and in some cases can make it look bigger (starts to get that 4x4 look to it). And no you do not need an alignment when changing rim diameter. However, if you lower the car, you will need an alignment.
Cost is hard to say because there are so many options & variables to both.
Old 01-13-2013, 08:31 PM   #3
Elgancho
Drives: SWP BRZ Limited MT
What the hell is this thread about?
Elgancho is offline   Reply With Quote
Old 01-13-2013, 08:33 PM   #4
Burrcold
Can you read?
The Following 2 Users Say Thank You to Burrcold For This Useful Post:
chenshuo (01-14-2013), Ingen (01-13-2013)
Old 01-13-2013, 08:34 PM   #5
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
Can't adjust computer to take into account a bigger wheel for MPH. It's all mechanical.
Best bet would be a slight lowering spring.
ZC6BRZ is offline   Reply With Quote
Old 01-13-2013, 09:10 PM   #6
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
If i go with a 18" wheel and have tire with the same side wall high, won't that make the wheel bigger hence throw off the speedo reading and the ODO reading?
So you guys suggest just lowering the car?
Old 01-13-2013, 09:31 PM   #7
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Lowering the car is probably the best way to reduce the wheel gap at low cost.
Mikepage is offline   Reply With Quote
Old 01-13-2013, 10:48 PM   #8
SLEEPER WRX
I lowered it 1 3/4 inches all the way around with KW V3’s
17 X 8 +48 wheels
I'm very pleased with he results
SLEEPER WRX is offline   Reply With Quote
The Following User Says Thank You to SLEEPER WRX For This Useful Post:
whataboutbob (01-14-2013)
Old 01-13-2013, 11:30 PM   #9
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
I have 18x8 +32 on mine lowered 1" on Hotchkis springs. Running 225/40 doesn't change the reading on the speedo until about 60 mph. And even then it's only less than 1mph above stock.
Here's a tire calculator so you can see the difference:
http://www.discounttire.com/dtcs/infoTireMath.dos
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 01-14-2013, 12:18 AM   #10
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
do u have picture?
Old 01-14-2013, 01:07 AM   #11
Calidrifter
@Executive_chicken
Suspension hasn't completely settled. I'll get one up of how it sits tomorrow.
Old 01-14-2013, 03:30 AM   #12
a.beck
Doing it wrong.
a.beck's Avatar
Originally Posted by chenshuo View Post
If i go with a 18" wheel and have tire with the same side wall high...
That's... really not how it works.
a.beck is offline   Reply With Quote
Old 01-14-2013, 07:38 AM   #13
BoostinIX
Gettin SIKKY sideways
BoostinIX's Avatar
Drives: '97 S14.5 / '13 BRZ
Send a message via AIM to BoostinIX Send a message via Yahoo to BoostinIX
Mach V Springs + Whiteline tops for alignment = done. Simple and cheap.
Instagram: BoostinIX
BoostinIX is offline   Reply With Quote
Old 01-14-2013, 08:46 AM   #14
sierra
Drives: Skoda Yeti DSG diesel 4x4
He wants to fill out the wheel arch and to do that evenly you would have to fit a larger wheel and tyre and then adjust the speedo.
By keeping the same diameter and lowering the car the gap at the top gets smaller or disappears but the gap front and rear remains the same and makes it look like it's collapsed.
You could fit 245/45-17 on the stock rims which are 26mm bigger diameter.
That would fill out the gap front/top/rear by 13mm but would also raise car by 13mm.
The speedo would probably be spot on with a 4.2% increase in actual speed against the reading.
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
Aftermarket fog solution hislargeness Mid-Atlantic 1 01-02-2013 06:19 PM
Frozen window solution? Ben_G Issues | Warranty | Recalls / TSB 21 12-17-2012 12:08 PM
any way to reduce or eliminate "idle creep"? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 8 07-03-2012 02:00 PM
My Exhaust solution for the moment Scooby South Engine, Exhaust, Transmission 42 06-18-2012 07:26 PM
Petition to Reduce Grey Market Imports from 25 to 15 years! chulooz Other Vehicles & General Automotive Discussions 3 12-05-2011 11:59 PM
