Old 11-01-2012, 09:57 PM   #1
Takeshi
Drives: Scion FR-S 6MT.
What socket size and what torque amount for stock alloy wheels?
I could not find a definite answer online or in the manual.
What torque setting in ft-lbs do I use? The manual mentions 89 ft-lb, however this is in direct reference to the spare tire (steely). Page 318. Other online references mention 80 ft-lb for scions 2004-2008.
What size socket do I need to buy for my 1/2" torque wrench? I measured the stock wrench inner diameter, and it's about 3/4". And this is a little over 19mm. Do I use 19mm?
Thanks so much.
Takeshi is offline   Reply With Quote
Old 11-01-2012, 10:04 PM   #2
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
Its a 19mm socket. The torque spec is 85 ft. lbs. for alloy and steelies. Its not the wheels but its the studs themselves.
VietnamPhenom is offline   Reply With Quote
The Following User Says Thank You to VietnamPhenom For This Useful Post:
Takeshi (11-01-2012)
Old 11-01-2012, 10:20 PM   #3
dsgerbc
Drives: BRZ(sold), STI
89 ft-lb, off FR-S FSM.
19mm socket.
The Following User Says Thank You to dsgerbc For This Useful Post:
Old 11-01-2012, 10:25 PM   #4
Takeshi
Thanks
Thanks for the quick replies!
2-piece stock size rotors? jm1681 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 01-16-2015 10:09 AM
Wheel Directory: Rota Torque 17x9.0 +30 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 113 09-09-2013 10:19 PM
Wheel Directory: Ace V12 18.0x8.5 +38 R2RO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-24-2013 01:23 AM
Getting a Stock HP and Torque Spreadsheet? nquillen Engine, Exhaust, Transmission 1 09-01-2012 04:00 PM
Alloy wheels (http://www.tirerack.com/wheels/) Loki556 AUSTRALIA 8 08-22-2012 10:13 PM
