Help me fine tunning my suspension setup
Hi there,
Id like to hear your thoughts on my setup. Its for track+street I'm running (1st gen):
And these are my questions: 1. Roll Center change because of lowering? Do you have a number of how much the RC decreases because of X lowering? On my calculations, I'm assuming (for 32mm drop):2. Roll Couple and LLTD I calculated these numbers: 61.7%, 56.8% (couple, LLT):3. Alignment Im planning to:The other aspect is that my bounce ratio is bad (0.97), I will play with damper settings and try find a good balance any feedback is appreciated
#3 | |
My current alignment is very conservative, I want to make the tail a bit happier but without overshooting Also I like to have the theoretic numbers so I can play and guess next mods (like ARB ot RC correction) |
#4 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
If you lowered the car 32mm then your roll centers are probably much much lower than what you assumed.
Generally on the McStruts, the RC will be affected an order of magnitude more than the ride height. All cases vary. Measure it yourself to be sure. BUT FIRST - consider Andrew’s question. ![]() Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to BlueWhelan For This Useful Post: | J95 (10-23-2025) |
#5 |
Drives: '23 BRZ
F/R toe looks fine. 0 front, OK. 0.7mm total(?) rear = 0.06 degrees total, cool. Even 0.7mm per side would be 0.12 degrees, also fine. Generally I'd say 0 to 0.15 degrees total rear toe has worked fine for me over the years (1st and 2nd gen).
Your proposed camber seems way low for track. I've run -3.0 to -3.5 front, with -2.8 rear camber all year, street and track, not a problem. Regarding lateral load transfer balance f/r, I say run what you have and see how you like the balance before going to any lengths to "fix" things that might not be a problem. |
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#6 | ||
It looks like a big enough change to think about correction Quote:
| The Following User Says Thank You to J95 For This Useful Post: | ZDan (10-24-2025) |
| 2016 frs suspension tunning va brz | jesse2021 | BRZ First-Gen (2012+) — General Topics | 6 | 09-11-2021 09:04 PM |
| Oft tunning help in Alanta Ga, metro area | sroby | Software Tuning | 20 | 01-03-2017 05:31 AM |
| Suspension tunning shop in riverside? | bleox | Southern California | 2 | 09-19-2016 05:12 PM |
| cobb tunning and the 2015wrx to the twins | subaruferrucci | Software Tuning | 5 | 04-24-2014 08:52 PM |
| Tunning risks? | topazsparrow | Engine, Exhaust, Transmission | 2 | 05-22-2013 07:07 PM |
